2002 ford taurus alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=63345
Printed Date: April 24, 2026 at 5:02 AM
Topic: 2002 ford taurus alarm
Posted By: domiyork
Subject: 2002 ford taurus alarm
Date Posted: September 27, 2005 at 10:01 AM
Hi,
Installing an alarm today on this unit, i was told that the power locks will become inactive after locking and closing the doors, and that the BCM on this vehicle sometimes will go on stand by and cause the alarm to give false reading. please help on how to bypass this.
thanks.
Posted By: tragik
Date Posted: September 28, 2005 at 10:10 PM
you have to trigger the door pin while you unlock to wake the locks up on this one. I think an 02 has a negative trigger door pin, but you may have to break the wire.
Northstart.....or start it your damn self.
Posted By: cntrylvr79
Date Posted: September 28, 2005 at 10:40 PM
You don't have to worry about the gem module shutting down in this car.  All you have to do is cut the BLACK/ orange wire in half and put a diode inline with the stripe side towards the gem module.  The nhook up the negative door trigger wire to the other side of the diode with the second half of the black orange wire.  Hope this helps.
