2004 grand am radio display problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=63361
Printed Date: April 23, 2026 at 8:53 PM
Topic: 2004 grand am radio display problem
Posted By: dr.thunder
Subject: 2004 grand am radio display problem
Date Posted: September 27, 2005 at 3:42 PM
I installed a r/s with keyless and trunk on a 04 pontiac grand am. Now the radio display is dead. The radio works fine but there is no display. Has anyone had this happen or is this just a really wierd coincidence.btw the radio was never dis connected from the car. thanks.
Posted By: kgerry
Date Posted: September 27, 2005 at 5:30 PM
what kind of bypass module did you use? you could have flashed the Class II data line if it's a data module.....
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: mo12v
Date Posted: September 27, 2005 at 9:15 PM
Also, the 04 pontiac grand am is known to have Display problems. I have seen..... Just unplugging it causes the same problem. We repair them often
------------- MO
Posted By: Slammed_Am
Date Posted: September 28, 2005 at 1:08 AM
I've actually seen GM radios(especially pontiacs) from 96-present have display issues. My moms was one of them.
Date Posted: September 28, 2005 at 7:35 AM
I used a omega DB-PASS-23 hooked to the databus plug under the dash. Any chance this can be fixed?
Posted By: mo12v
Date Posted: September 28, 2005 at 8:22 AM
Should have GM warranty on Radio......Have Dealer check it
------------- MO
Posted By: kgerry
Date Posted: September 28, 2005 at 9:17 AM
display problems were common on pre-200 Pontiac radios that used a single lamp in the display... 2000-up radios have 3 separate AVR circuits with 3 separate lamps in the LCD display.... the chance of all 3 going out at the exact same time is pretty darn coincidental..... as an AC Delco radio repair center we service lots of these units for partial display failure, but i dont think i've seen one yet where they all went out.....
Owner/Installer
Classic Car Audio
since 1979
Posted By: mo12v
Date Posted: September 28, 2005 at 9:47 AM
That is how I have seen at least 4 in the past year...."coincidental" We do MOPAR, FORD & Delco warranty...........GM is the all most as bad as Ford I think GM has a Static Discharge Problem ------------- MO
Date Posted: September 28, 2005 at 2:47 PM
So this radio needs a trip to the dealer for repair?
Posted By: mo12v
Date Posted: September 28, 2005 at 3:21 PM
If it has Warranty it is worth the trip .....But make sure you don't have a fuse out up front
------------- MO
Posted By: kgerry
Date Posted: September 28, 2005 at 5:27 PM
it wont be a fuse out if the radio still works..... it only has 1 fuse....
Owner/Installer
Classic Car Audio
since 1979
Date Posted: September 30, 2005 at 7:41 AM
thanks for the help. I'll take it to the dealer.
