91 BMW door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=63483
Printed Date: April 19, 2026 at 12:09 PM
Topic: 91 BMW door locks
Posted By: extremeconcepts
Subject: 91 BMW door locks
Date Posted: September 29, 2005 at 1:21 PM
I used the diagram on this forum and caught the 5 wire at the ZV Module behind the glove box. The locks will unlock with no problem, but on lock activation, they will not move. I can hear the motors trying, but no motion. Anyone have any other ideas?
Posted By: mo12v
Date Posted: September 29, 2005 at 3:27 PM
What Model BMW It may have the Dead-Bolt System which prevents the Doors from Unlocking unless another method is used
------------- MO
Date Posted: September 29, 2005 at 4:51 PM
Manufacture date is 7/91. There are no relays in driver kick, no alarm plug behind glove box, only ZV Module high in pass. kick. Also when I grab the two wires at the ZV module, I loose all functions from the drivers key cylinder. This car is whipping my *@#!!
Posted By: Evolution-UK
Date Posted: September 29, 2005 at 4:54 PM
Is this an E36 or E30 model BMW ?
Date Posted: September 29, 2005 at 5:36 PM
hOW CAN i TELL THE DIFFERENCE? iTS A 325I
Date Posted: September 29, 2005 at 5:41 PM
This is an E30 model.
https://www.unixnerd.demon.co.uk/e30.html
and this is an E36
https://www.cardomain.com/ride/2074082
Date Posted: September 29, 2005 at 5:44 PM
its an E36
Posted By: mo12v
Date Posted: September 29, 2005 at 5:47 PM
| Power Lock | YELLOW/BLUE | DRIVER KICK | | Power Unlock | GREEN/ BLUE see note** | PANEL | Negative Pulse Door Locks BMW Deadbolt Door Locks : **Note: https://www.wiringinstructions.com/208.htm------------- MO
Date Posted: September 29, 2005 at 5:53 PM
thats wrong Mo12v. Those are for an E30
Does your ZV module have a White plug or a Yellow Plug ?
White plug pins is 24-25 Yellow Plug is pins 4 - 17
The doors locks probably wont operate if there is a door open.
Date Posted: September 29, 2005 at 5:54 PM
There is a white plug on ZV Module. I've seen where I can add wires to this plug on 24 and 25, but I don't know where I can get pins to fit the plug.
Date Posted: September 29, 2005 at 6:10 PM
OK you have 2 options.
1/ remove the battery terminals then unplug the module. Open it up and locate pins 24-25 on the board. Solder 2 wires onto the board, drill a hole in the black box case and bring the 2 wires out of the box. This is the way that i would do it.
2/ Split the plug down that plugs into the control module. Strip 10-15mm from the ends of your CDL control wires (ones from the alarm unit). Tin the bared ends with your solder iron and insert these into the holes where the pins would be located inside the plug. Rebuild the plug then insert it into the control module.
Not an ideal way of doing it but it works.
Date Posted: September 30, 2005 at 9:09 AM
K thanx, I soldered in the ZV module and everything works great. Thank you for your help
