1995 EU Ford Escort Remote Upgrade
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=63537
Printed Date: April 19, 2026 at 12:09 PM
Topic: 1995 EU Ford Escort Remote Upgrade
Posted By: pyrozz
Subject: 1995 EU Ford Escort Remote Upgrade
Date Posted: September 30, 2005 at 11:57 AM
I have an Escort 1995 European! It currently has central locking and i would like to upgrade this to remote. I have the remote locking module. The module has the following wires:
+12v
Gnd,
Lock,
Unlock,
Lock/Unlock Signal,
Boot Release
Hazard Flasher
I need to know where to hack into existing wires for the module for the
12v,
Gnd,
Lock,
Unlock and Lock/Unlock Signals.
Remember it is not a American Escort, it is a British right hand drive Ford Escort 1995 (mk6).  Any help appreciated.
Posted By: Evolution-UK
Date Posted: September 30, 2005 at 12:30 PM
Power LocK - yellow or yel/blk              12v+
Power Unlock - white or wht/vio      12v +
12V - Drivers sill loom going to back of car, or on top of the fusebox.
GND - Drivers kickpanel. There should be a ground point already there.
Lock and Unlock can be found in the plugs which are located in the drivers kick panel. This is the loom which goes into the drivers door.
Easy car to do. Should take you no more that 10 min to do.
Posted By: pyrozz
Date Posted: September 30, 2005 at 4:04 PM
what colour is the 12v? Red i presume?
Date Posted: October 01, 2005 at 2:41 AM
yeah
Posted By: pyrozz
Date Posted: October 01, 2005 at 9:21 AM
I pulled off the driver's door sill, and i found a cable, which i presumed is the speaker cable. I pulled up the carpet and found 2 wiring looms. Both of these looms have red cables, which one do i connect to?
Date Posted: October 01, 2005 at 10:03 AM
the one that measures 12v with your testlight/ multimeter.
Posted By: pyrozz
Date Posted: October 02, 2005 at 10:42 AM
I wired it up and it works OK.
Only thing is i want to wire up the indicators. Is there a hazard wire or do i need to use 2 diodes with the left and right indicator wires?
Date Posted: October 02, 2005 at 1:00 PM
2 diodes. wires can be found in loom running to the back of the car
Posted By: pyrozz
Date Posted: October 02, 2005 at 3:19 PM
Do you know where the +12v and ground wires can be found on a 96 post facelift model? Tried to help my mate who doesnt have a red 12v wire, dont want to hack into them if i dont know which one it is.
Posted By: pyrozz
Date Posted: October 02, 2005 at 3:55 PM
Got any suggestions for diodes from maplin?
Posted By: pyrozz
Date Posted: October 02, 2005 at 4:11 PM
Never mind, i found some suitable ones :D
Posted By: pyrozz
Date Posted: October 02, 2005 at 4:47 PM
Back to the post face lift question above... any ideas?
Posted By: pyrozz
Date Posted: October 04, 2005 at 8:01 AM
i've been informed elsewhere that the colour on a 96 escort for 12v constant is brown. Is that correct?
