2003 civic tach wires
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=63549
Printed Date: April 19, 2026 at 8:26 PM
Topic: 2003 civic tach wires
Posted By: chrisati
Subject: 2003 civic tach wires
Date Posted: September 30, 2005 at 1:41 PM
Im trying to install remote start on my 2003 honda civic lx coupe.  Ive got the remote start to work but the starter wont disengage, I was thinking probably because its hooked up to voltage sense.?.  I need help locating the tach wire cause i cant find it.  Ive heard a 2 pin connector on the passenger side by the battery, but cant find it.  Need a little help here.
thanks, CsC
CsC
Posted By: mo12v
Date Posted: September 30, 2005 at 1:57 PM
Tach SignalBLUE2 PIN CONN BY BATTERY *
* Alternate Tach Signal At 8 Pin Grn Conn At Underdash Relay Box
MO
Posted By: gus1
Date Posted: September 30, 2005 at 3:25 PM
Also, at the fusebox under the dash near the top. There is a 14pin or so connector.... at the right end of it, there is a blue/white and a blue right beside each other on the top row. Tach is the blue (the blue/white is vss, BTW).
The One under the hood is right beside the battery, taped to a harness, one blue wire by itself in a 2pin plug with a rubber boot on it. You should see it if you look down the fender side of the battery, behind the passenger headlight.
Gus
Posted By: ringojam
Date Posted: September 30, 2005 at 6:39 PM
Why not go to a tach wire and make life eaiser,On the hondas on left wire loom near the bonnet hinge is a little black rubber relay with a blue wire commin from it just tap int itposted_image
Posted By: chrisati
Date Posted: October 01, 2005 at 2:25 AM
can anyone get a picture of the location?
CsC
Posted By: Velocity Motors
Date Posted: October 01, 2005 at 9:19 AM
Posted By: chrisati
Date Posted: October 01, 2005 at 1:14 PM
thanks for the pic im going to look for it right now
CsC
Posted By: profuse007
Date Posted: October 01, 2005 at 2:48 PM
click on my sig for the tutorial, if needed.
Houston,TX
Posted By: chrisati
Date Posted: October 02, 2005 at 6:55 AM
hell yeah i found it thanks to the pic, thanks peeps
CsC
Date Posted: October 02, 2005 at 10:35 AM
No problemo
