strobe light package
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=63696
Printed Date: April 25, 2026 at 1:34 AM
Topic: strobe light package
Posted By: mrcllusb
Subject: strobe light package
Date Posted: October 03, 2005 at 6:14 AM
I'm thinking of adding a 4 light strobe package,and was wondering what would be a good wattage?Also,i want it to only come on if the alarm is activated,and leave just the parking lights for normal on/off operation.How would i go about doing this??
"ole blake"
Posted By: sneakycyber
Date Posted: October 03, 2005 at 9:59 AM
Crimestopper offers some high quality units from strobetronix. Depending on the alarm system there should be a grounded when armed wire that you can use to power a relay to activate the strobes.
Posted By: mrcllusb
Date Posted: October 04, 2005 at 5:41 AM
Crimestopper is high.They want 220.00 for a 4 light kit that i can get from whelen for 160.00
"ole blake"
Posted By: mrcllusb
Date Posted: October 04, 2005 at 5:51 AM
I have a Green(armed out-)wire.Is this what you mean??
"ole blake"
Posted By: mrcllusb
Date Posted: October 08, 2005 at 6:13 AM
Anyone with anymore info about this?
"ole blake"
Posted By: Chris Luongo
Date Posted: October 08, 2005 at 8:28 AM
I've installed a few strobe sets. I'm very new to this but I'll tell you the basics of what I know.
--You need a 1" hole saw to install the bulbs. $10 at Lowe's.
--A little silicone is also helpful to put around the bulbs, even though they have their own gasket.
--The plugs for the bulbs are not waterproof, even though they have to stay on the "outside" of the car. Some people put silicone over the plugs, which makes bulb replacement difficult. Tape wouldn't be as good as silicone, but better than nothing.
--www.lshlights.com is a good company that has wholesale prices.
--60 watts per channel is the standard for the power supply. I know a guy who sells the 50-watt kits and no one notices or complains, so it is probably good enough.
--The strobe kit asks for ground, constant power, and switched power. Connect the ground and constant as usual. Connect the switched wire to the siren wire for your car alarm----the strobes will only operate when the siren is on.
--Most of the strobe power supplies have a wire for changing the pattern. Every time that wire receives positive power, the strobe pattern changes. You can wire in a valet switch from an old alarm to change patterns------or if you don't want to change the patterns, use a jumper wire to set it the way you like, and then leave it.
--If this is your personal car, I would STRONGLY recomment installing an indicator light on the dash to show you that the strobes are on, in case something goes wrong.
I had a customer who had his strobes come on whenever his parking lights were on, because of an install error of mine. He got pulled over and warned, but luckily no ticket. If I had installed an indicator light, he would have known about the problem, and probably would have stopped driving until I fixed it.
Posted By: mrcllusb
Date Posted: October 08, 2005 at 9:04 AM
Thanks for the info Chris.I appreciate it
"ole blake"
