Alarm/Remote Start Wiring for 2004 Malibu Classic
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=63706
Printed Date: April 25, 2026 at 4:30 AM
Topic: Alarm/Remote Start Wiring for 2004 Malibu Classic
Posted By: aipsaro0919
Subject: Alarm/Remote Start Wiring for 2004 Malibu Classic
Date Posted: October 03, 2005 at 9:51 AM
I have a 2004 Chevy Malibu Classic and a BW-3000 Black Widow security system. Does anyone have a wiring diagram for this vehicle and alarm? Thanks!
Anthony Ipsaro
Posted By: thepencil
Date Posted: October 03, 2005 at 10:26 AM
DIRECTWIRE™ WIRING INFORMATION - CHEVROLET / MALIBU / 2004 / Remote Start
12volts RED / black (50A)   +   BCM, C3, pin D1
Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug.
Starter yellow (not for remote start)   -   PCM, blue plug, pin 48 or 23
Notes: Starter wire is not required for remote start. When the vehicle sees that the ignition wire has voltage and the accessory wire lose voltage, it automatically cranks the starter.
The PCM (Powertrain Control Module) is in front of the battery on the driver side fender.
Second Starter N/A
Ignition pink   +   ign harn or BCM, C4, pin D3
Second Ignition N/A
Third Ignition N/A
Accessory brown   +   ign harn or BCM, C4, pin C8
Second Accessory N/A
Keysense not required
Power Lock white   -   driver kick or BCM, C1, pin 66
Notes: Lock is a straight negative trigger. Unlock is negative trigger thru a 1.5K ohm resistor. MUST use relays.
Power Unlock same as power lock wire
Lock Motor gray/black to gray   5wi driver kick or BCM, C3, pin A5
Unlock Motor tan   5wi driver kick or BCM, C3, pin B1
Parking Lights+ brown   +   driver kick or BCM, C3, pin A7
Parking Lights- BROWN / white   -   switch or BCM, C2, pin 5
Hazards white   -   switch or BCM, C2, pin 9
Turn Signal(L) dk. blue (F), yellow (R)   +   BCM, C1, pin 38 and C3, pin A9
Turn Signal(R) dk. green (F), dk. green (R)   +   BCM, C1, pin 56 and C3, pin A12
Reverse Light lt. green   +   fuse block, driver side of trunk
Door Trigger gray/black (D), tan/white (P)   -   each kick or BCM, C1, pins 51and 72
Notes: Use both wires and diode isolate each.
Dome Supervision gray   -   BCM, C3, pin A10
Trunk/Hatch Pin ORANGE / black   -   BCM, C1, pin 18
Hood Pin pink/black   -   pin switch or BCM, C1, pin 69
Trunk/Hatch Release BROWN / white   -   switch or BCM, C1, pin 71
Power Sliding Door N/A
Factory Alarm Arm factory remote only
Factory Alarm Disarm factory remote only
Disarm No Unlock with ignition and Passkey
Tachometer NOT pink   ac   any fuel injector
Wait to start N/A
Brake Wire white   +   BCM, C1, pin 42
Parking Brake lt. blue   -   switch or BCM, C1, pin 59
Horn Trigger tan   -   switch or BCM, C2, pin 14
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
PASS-Key III+
Part #: 556UW
Alternate Part1 #: 555U
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: Standard on all models.
Door Lock Interface Required:
Yes Type:
Multiplex
Part #: 456LW
Notes:
Be careful whose advice you buy, but be patient with those who supply it.posted_image
Date Posted: October 03, 2005 at 11:25 AM
Thanks for the info!! I am not putting in a remote start just the alarm will i still need an immobilizer bypass? And also the vehicle has factory keyless entry. Will the aftermarket alarm interface with the factory keyless entry and if it does not interface then will using the aftermarket alarm conflict in anyway with the vehicle functions as far as the keyless entry system?Thanks again!
Anthony Ipsaro
