Installing a door lock actuator in a 1987 RX-7
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=6371
Printed Date: May 11, 2026 at 7:45 AM
Topic: Installing a door lock actuator in a 1987 RX-7
Posted By: crashster21
Subject: Installing a door lock actuator in a 1987 RX-7
Date Posted: December 08, 2002 at 11:41 AM
I was wondering if anyone out there has installed a doorlock actuator in a 1986-1991 Mazda RX-7.  I purchased the DEI Rattler 359D Remote Starter and Keyless entry and just wondered if anyone had installed the actuator in the door of an RX-7 before.  Thanks to anyone who can help me, i just need to know where exactly the actuator should be mounted.
Posted By: cpgoose
Date Posted: December 09, 2002 at 11:37 AM
I haven't done it in the mazda, but I've done it (twice) in a second generation Integra.  I'm not positive what the door panel looks like in the rx7, but in my car, I was able to mount the actuator on the door behind the armrest of the door panel.  In other words, behind the door's armrest, there's a good space of room, so when you put the panel back on, it fits over the actuator.  HOpe that helped :)
Posted By: kickyride
Date Posted: December 09, 2002 at 3:49 PM
Hey crashter, I've done a few of these. I just use the large open space to the rear of the driver's door. The actuator should mount facing the front and it should be below the lock control rod. I think I used an extra piece of backstrap to stabilize the motor because the included piece wouldn't reach across the opening. It is a pretty easy install. If you have any other questions about this, let me know while it's still vivid in my mind posted_image. Hope this helps.
Mike
Sales/Tech Support - KICKYRIDEoCOM mobile electronics
MECP 1st class-Security Specialist
Date Posted: December 09, 2002 at 9:46 PM
Thanks mike, I actually just put it in today, (Monday) and put it just to the right of that large hole and used the supplied support brace.  The actuator did push a little on the door panel, but you can't tell.  thanks alot for the help.  have a good one
