windows go up when i lock the car
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=63733
Printed Date: April 02, 2026 at 7:10 AM
Topic: windows go up when i lock the car
Posted By: lowone01
Subject: windows go up when i lock the car
Date Posted: October 03, 2005 at 5:57 PM
How can i have my windows go up when i lock the car from the key fob. i am using a factory key pad on a 2003 mazda protege 5
Posted By: youngone
Date Posted: October 03, 2005 at 8:22 PM
sounds like it is built into the car. is it suppesd to do that
------------- Want to know some good equipment- JL,Adire Audio,Mcintosh,Brax,Helix,Eclipse,JBL,RE,Dimoand Audio,Zapco, pritty much anything DYhon,Forbidden recommend
On the12volt you give some info and you get in
Posted By: tragik
Date Posted: October 03, 2005 at 8:58 PM
If you can roll the windows up by turning the key in the door, then all you need is a pulse timer. DEI Makes one called the 555t i think. Set it up so that it sends a longer pulse than the one your keyless does to the lock cyclinder wire. You can do it with a relay and a capacitor too, but you'd probobly be better off with the timer.
------------- Northstart.....or start it your damn self.
Posted By: auex
Date Posted: October 03, 2005 at 9:10 PM
Buy an alarm and a window module.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: redpeppers
Date Posted: October 03, 2005 at 11:49 PM
window mod is the smart's way 2 do it.....it has resistance dip switches that will keep u from messing up ur windows and window motors
------------- Where theres is a wire there's a way.
