Grand Cherokee Auto Unlock
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=6375
Printed Date: May 11, 2026 at 11:20 AM
Topic: Grand Cherokee Auto Unlock
Posted By: thatcher
Subject: Grand Cherokee Auto Unlock
Date Posted: December 08, 2002 at 12:32 PM
Everyone that I know that owns a Grand Cherokee with the auto-lock after ignition and drive wants the doors to unlock automatically upon key removal.  Specific information on the door locks and relay would be appreciated.  I also own a 99 cherokee that doesn't have auto-lock, or auto unlock, like my wife's '97 Grand Cherokee, and I want to also add that feature to my Jeep.
So I guess my question is the type of door locks used in Jeeps, ie. positive vs. negative, and where should I start looking for relays etc.  I have a basic knowledge of electronics, enough to do damage but not enough to have it "click right away". Please help!!!
Thatcher Ernette "It's a Jeep Thing...I DO understand!!"
Posted By: mxxmikexx
Date Posted: December 08, 2002 at 4:49 PM
a databuse wire controls the lock, unlock, factory alarm, and domelite, located at the test connector under the dash, and you need a module to interface with it. therefore im not really sure if you can do what you want to do.
Posted By: Velocity Motors
Date Posted: December 08, 2002 at 5:11 PM
Both year jeeps use a 5 wire reverse polarity system through a multiplex module.
1999 Jeep GC: Use ORANGE / black and pink/black at the drivers door lock switch to lock and unlock the drivers door.  Use ORANGE / purple and pink/purple at the passengers door lock switch to lock and unlock all of the other doors.
1997 Jeep GC: Use ORANGE / purple for lock and pink/black for unlock at the drivers door switch to operate the drivers door lock.   Use BLACK/ white for lock and pink/black for unlock at the passenger front door switch to unlock all passenger doors.  It is required to interface in each door even if the vehicle is equiped with keyless entry.
Posted By: thatcher
Date Posted: December 09, 2002 at 4:39 PM
Thanks for your input, sounds like the issue is rather complex for my knowledge/experience.  Would anyone know where I could find a control module to fix the annoying lack of auto-unlock?
Date Posted: December 09, 2002 at 5:57 PM
Most aftermarket keyless entry or alarm systems ( even remote starters ) have this option for any vehicle.
