bad brain or remote?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=63798
Printed Date: April 01, 2026 at 3:55 AM
Topic: bad brain or remote?
Posted By: hondaccord94
Subject: bad brain or remote?
Date Posted: October 04, 2005 at 5:58 PM
Well ive been having some problems the past day or 2. some reason my remote will pick up my sisters alarm signal/code, adn disarm both our cars when its not even programed, it does it vice versa also too. i know as a fact this cant be normal operations. we both have the same alarm, viper model 3000, only the 2 way remote will do this. the spare remote doesnt have this problem at all. my friend told me to get out of range and press my transmitter butting about 10-20 times. he said this will work and the signal/code will be randomized, is this true?
maybe i have a bad remote?, bad unit? or could it be both systems??
i tried reset everything to default settings, add my remote 4 times to the system, removed the battery on one of the remote while programming/add the transmitter to the proper car.
any help would be greatly appriciated...
Car: honda accord 94 & acura integra 93
Alarm: Viper model 3000
BTW, i installed the alarms 1 day apart, does that effect anything? i got scared my car might get breaking into becuase my sisters car got broken into the night before i installed the alarm.
Posted By: dare_ds69
Date Posted: October 05, 2005 at 5:53 AM
well you have to do is erase all the remotes in both cars, and program it again and if you have the bitwritter lock the remotes so nobody can add a remote in you car.
------------- how own your mind, control your life.
MECP certified. always use a DMM
Date Posted: October 06, 2005 at 12:33 AM
I have alreayd done that, after deleting all transmitter, the system revert back to default settings. same thing happens. anyone else have advice or solution to this problem? thanks!
Posted By: kgerry
Date Posted: October 06, 2005 at 6:01 PM
have you tried programming one for code hopping on and the other for code hopping off?
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Date Posted: October 07, 2005 at 2:28 PM
will turning "code hopping" off will effect anything as secutity wise?
Date Posted: October 09, 2005 at 8:27 PM
alright same problem is occuring for me. im getting pretty sick of this and looks like no one else has this problem. i giving it one more shot before im going to return one of the alarm and getting a different one.
