1998 chevy S-10 Blazer power door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=63866
Printed Date: May 09, 2026 at 6:09 AM
Topic: 1998 chevy S-10 Blazer power door locks
Posted By: mac444
Subject: 1998 chevy S-10 Blazer power door locks
Date Posted: October 05, 2005 at 6:01 PM
I just installed a Astra 777 alarm system. this vehicle has positive trigger door locks. I installed 2 relays for the locks as the alarm has negative door lock outputs. I connected the positive outputs from the relays to the BCM door lock wires. the locks work ok but now blows the 15amp fuse in the oem fuse block. was I wrong in wiring the relays into the BCM? should I connect the relays into the door lock switch wire at the door? I also have seen a wire kit that will change the alarm from negitive output to positive output. Thanks for any help that will lead me in the right direction.
Posted By: mo12v
Date Posted: October 05, 2005 at 7:24 PM
I wire it at the Body BUSSED Electrical Center..Above the Emergency Brake.
Just Meter first
Power LockL BLUEAT BODY BUSSED
Power UnlockWHITEELECTRICAL CENTER *
* Body Bussed Electrical Center Is Located Behind The Driver Dash Above The Driver Kick Panel & Emergency Brake.
Positive Pulse Door Locks
MO
Posted By: mac444
Date Posted: October 05, 2005 at 7:57 PM
I have un-pluged the alarm system and disconnected the wires that I connected to the BCM lock wires but is still blowing the OEM door lock fuse. Do you think I fried the body control module? I can still hear the oem relays click when i push the door lock switch or the factory lock remote. Thanks for your reply.
Posted By: nava94
Date Posted: October 05, 2005 at 10:27 PM
connect the factory wires back together. if the problem persists then you fried your bcm.
