remote lcd pager
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=6392
Printed Date: May 11, 2026 at 3:12 PM
Topic: remote lcd pager
Posted By: darkchild
Subject: remote lcd pager
Date Posted: December 08, 2002 at 8:25 PM
has any body installed any of the ebay remote lcd pager alarms i have heard a couple of things about them and there senstivety i heard they go off if you breath on them what do you think is the best one out of all of them
Posted By: Velocity Motors
Date Posted: December 08, 2002 at 8:56 PM
Dependson which ones. The cheap 3 button ones that I've seen and installed ( with Roman numerals on the buttons ) are not very good and are limited in installation options. For the price I guess it's a goo d buy, but would you rely on a $ 100.00 alarms system for your $ 25000.00 vehicle ??
Posted By: floaterr
Date Posted: December 09, 2002 at 6:47 AM
You can also get them here https://www.commandocaralarms.com
I've seen 3 versions of the same unit under a different name. Marksman, Auaotpage, and Compustar.org (how'd they get an .org?). they all use almost the same brain which includes remote start, in car temp sensor which can be seen on the remote (cool to see the inside temp of the car from the house!) and "tap on widshield to page driver". watch out cause the marksman is $$$$ high for some reason and doesn include the shock/temp sensors. Buddy of mine has it on his tahoe and it works fine. Vibrate and beeps during the different operations. Thing is actually the bomb.
As for falsing are you referring to the shock sensor? Thats the only thing going to cause the alarm to go off if breathed on and that 99% of the time installer error.
