viper 791xv problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=64280
Printed Date: May 14, 2026 at 5:42 PM
Topic: viper 791xv problems
Posted By: bluesbabybones
Subject: viper 791xv problems
Date Posted: October 13, 2005 at 12:06 AM
well tonight i had my had my radio on most of the day and battery went dead. no big deal so i jumped my truck and for some reason my 2way responders dont work any more. is there any way to reset them?
Posted By: redpeppers
Date Posted: October 13, 2005 at 12:14 AM
did u try to pull the batt out of the remote?  also try unpluging the ant......if neither of these work...u may have blown the main 13 amp fuse on the red 12v+ wire off the brain.........also is it the same remote that came with the brain or is it different?
Where theres is a wire there's a way.
Date Posted: October 13, 2005 at 12:25 AM
no i didnt try disconnecting the battery cause the battery was basically dead before i started it which caused this. yes i tried taking the batteries out of both remotes and it didnt change anything. i didnt try unplugging the antenna but i can try that.
Date Posted: October 13, 2005 at 2:34 PM
could my antenna be bad? i put a charger on the battery and used that to give it a little bump. but someone told me the charger might have blown the receiver and i might need a new antenna. is this possible?
Date Posted: October 13, 2005 at 5:01 PM
well after doing more searching on the forum, i found out all i had to do was disconnect the wires to the brain for about 10 min. and plug it back in.  everything works fine now. I LOVE THIS SITE!!!
