Acura Integra 90’ clutch bypass?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=64513
Printed Date: May 15, 2026 at 6:47 PM
Topic: Acura Integra 90’ clutch bypass?
Posted By: ekdude
Subject: Acura Integra 90’ clutch bypass?
Date Posted: October 17, 2005 at 3:42 AM
Car: Acura Integra
Year: 1990
Transmission: 5 Speed
Alarm: Compustar 2WFMAS
What is the correct way to wire up a relay to bypass the clutch on the Acura Integra 1990?
Posted By: Velocity Motors
Date Posted: October 17, 2005 at 8:05 AM
The clutch on the Acura is a (-) trigger so you can use the BLACK status output wire to trigger the clutch during remote start. You will also need to grab the emergency brake wire aswell from the switch itself at the center console.
Date Posted: October 17, 2005 at 9:09 PM
I don't know. That's what I've called it for years. I guess you call it what you've been brought up with and all my buddies always called it an e-brake.
Posted By: ekdude
Date Posted: October 31, 2005 at 9:50 PM
do i just take the output status wire and tap directly into the clutch negative trigger wire? or do i need to use a relay? If so, then what are the terminals on the relay?
Date Posted: November 01, 2005 at 10:06 AM
You can do either. If you use a relay, wire in the relay like this:
https://www.velocitymotorsport.com/images/install_notes/N2N.jpg
