Viper 791xv remote start and starter kill
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=64532
Printed Date: May 15, 2026 at 12:29 PM
Topic: Viper 791xv remote start and starter kill
Posted By: maxspeeds
Subject: Viper 791xv remote start and starter kill
Date Posted: October 17, 2005 at 1:54 PM
Is it possible to utilize the remote start on the viper 791xv and not use the starter kill?  Reaon I ask is because my starter kill sometimes engages when the alarm is not armed.  So, I cannot start my car with my car's key.  I was thinking of doing the following:
Disconnecting the green wire (that goes to the key side of the starter wire) and reconnecting the vehicle's starter wire that was originally cut.  This way, the vehicle's starter wire will be uninterupted (so the car will always start with the ignition key) and remote start can still be activated because the purple wire from the viper alarm is still connected to the vehicle's starter wire)
Date Posted: October 17, 2005 at 2:52 PM
i have my neutral safety wire hooked up.
Posted By: kgerry
Date Posted: October 17, 2005 at 3:22 PM
sure you can do that... you will lose the anti-grind feature as well......
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: redpeppers
Date Posted: October 17, 2005 at 8:49 PM
put the factory starter wire back together and just wire the purple wire to the starter wire and disguard the green wire.......
Where theres is a wire there's a way.
Posted By: chriswallace187
Date Posted: October 17, 2005 at 11:09 PM
Your starter kill/anti-grind should only be engaging when the alarm is armed or the remote start is activated.
C Renner's Auto Electronix
Posted By: tragik
Date Posted: October 18, 2005 at 1:25 AM
you should be able to program the starter kill not to arm passively.
Northstart.....or start it your damn self.
Date Posted: October 30, 2005 at 10:55 PM
That sounds like a good alternative.  That will allow me to maintain the anti-grind feature.  Does anyone know how to make viper's starter kill to not arm passively?
