LED stays on
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=64644
Printed Date: May 13, 2026 at 7:24 PM
Topic: LED stays on
Posted By: msascarbrough
Subject: LED stays on
Date Posted: October 19, 2005 at 7:18 AM
My led on my aps590 will not go off once the vehicle is cranked. It will reset the flashes but stays on constant. Does anyone have any clues?
Mike
Posted By: thepencil
Date Posted: October 19, 2005 at 8:33 AM
You have enter Valet Mode.
Switch the key on to ignition.
Press the and release the valet switch three times, then you should be out of valet mode.
If not, refer to your owners manual for the correct procedure to get out of valet mode.
Be careful whose advice you buy, but be patient with those who supply it.posted_image
