1995 Toyota Camary
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=6467
Printed Date: April 28, 2026 at 8:07 PM
Topic: 1995 Toyota Camary
Posted By: brianh
Subject: 1995 Toyota Camary
Date Posted: December 10, 2002 at 7:48 AM
I am puting a remote start/keyless entry unit in this vehicle.  Tell me if I am right.  Because of the child saftey lock system I need to send a ground to the unlock wire and at the same time the saftey wire to disable the child saftey lock system.  Do I just  diode isolate two wires off of the unlock wire ?  I belive this vehcle is a (-) trigger so I should face the striped side of the diode toward the alarm system,right?  Any help you could sent my way will help. Thanks in advance.  Brian
Posted By: 10nesne1
Date Posted: December 10, 2002 at 10:02 AM
posted_image
Posted By: brianh
Date Posted: December 10, 2002 at 10:05 AM
thanks for the information.  I thought I had it right but I wanted to double check.  Brian
