BOA 165b remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=64672
Printed Date: May 13, 2026 at 8:00 AM
Topic: BOA 165b remote start
Posted By: smair1984
Subject: BOA 165b remote start
Date Posted: October 19, 2005 at 4:15 PM
I just installed the BOA 165b remote start system on my 1995 Dodge Avenger. I followed the instructions and tested to make sure all the wires were hooked up correctly but i still can't get the thing to work. When i go to program the remote the lights don't flash as the instructions say and the car won't start, nor will any accessories come on. Here is the diagram for my car. Any suggestions or help would be appreciated...
DIRECTWIRE™ WIRING INFORMATION - DODGE / AVENGER / 1995 / Remote Start
12volts white + ignition harness
Starter BLACK/ red + ignition harness
Second Starter
Ignition BLACK/ white + ignition harness
Second Ignition
Third Ignition
Accessory blue/black + ignition harness
Second Accessory
Keysense
Power Lock BROWN / white - driver kick, door harness
Power Unlock brown - driver kick, door harness
Notes: To unlock only the driver door on models with keyless entry, use BROWN / blue (-) at the relays behind the radio.
Lock Motor blue/black 5wi driver kick, door harness
Unlock Motor blue/red 5wi driver kick, door harness
Parking Lights+ GREEN / WHITE + driver kick, harness to rear
Parking Lights- GREEN / WHITE - headlight switch
Notes: Found in a gray 20-pin connector.
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger RED / green - driver kick, harness to rear
Notes: To avoid the dome light delay use RED / white (-) at the door open indicator at the instrument cluster. The RED / white will also catch the rear hatch.
Dome Supervision use door trigger wire
Trunk/Hatch Pin RED / green - driver kick, harness to rear
Hood Pin blue/black - fuse box
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm GREEN/ YELLOW - driver kick, door harness
Notes: Meter this wire while turning the key in the driver door key cylinder.
Can also use the passenger door key cylinder which is RED / blue (-) in the passenger kick, door harness.
Factory Alarm Disarm GREEN / WHITE - driver kick, door harness
Can also use the passenger door key cylinder which is BROWN / red (-) in the passenger kick, door harness.
Disarm No Unlock see factory alarm disarm
Tachometer white ac instrument cluster or PCM
Notes: The PCM is located on the drivers side of the engine compartment or behind the center of the dash depending on motor.
Wait to start
Brake Wire GREEN / WHITE + brake pedal switch
Parking Brake
Horn Trigger GREEN/ black - horn switch
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: Type: Part #:
Notes:
Date Posted: October 19, 2005 at 4:47 PM
alright, using the test wire (blue/white) i got the engine to crank and accessories to come on, however the car doesn't start. Additionally, the remote still won't work. I've read some of the other posts on the forums and i can't seem to fix the problem.
Posted By: Fastlearner
Date Posted: October 19, 2005 at 6:25 PM
get a new remote start. Those things suck.
Posted By: swamprat323
Date Posted: October 19, 2005 at 7:03 PM
yes just get ride of it, even knwo is it made by DEI it is crap. there is alot of programing problems with those units. do a search you find them.
Date Posted: October 20, 2005 at 3:48 PM
Thanks for being condescending guys, your answers were a ton of help.
Date Posted: October 20, 2005 at 7:35 PM
the problem with these units is to get it to "program". i never delt with them my self but just read on thsi site abotu them. do a search on it and see waht they did.
Posted By: mo12v
Date Posted: October 20, 2005 at 7:39 PM
Make sure the Unit is NOT in Valet when you start
------------- MO
