1999 Acura Cl wiring and remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=64680
Printed Date: May 13, 2026 at 6:21 AM
Topic: 1999 Acura Cl wiring and remote start
Posted By: sep266
Subject: 1999 Acura Cl wiring and remote start
Date Posted: October 19, 2005 at 8:08 PM
Okay I have never installed anything on this car before. If anyone has installed a remote start on this car and has any tips please go for it. Also, if someone has a wiring diagram for this car that would help with the installation of the remote start please post. As well, is the door trigger the same wire as the facotry secuirty rearm.
Posted By: thepencil
Date Posted: October 19, 2005 at 8:24 PM
ACURA CL 1999
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|white               |+ |ignition harness            |
|          STARTER|BLACK/ white        |+ |ignition harness            |
|        IGNITION|BLACK / YELLOW *1     |+ |ignition harness            |
|        ACCESSORY|yellow              |+ |ignition harness            |
|       POWER LOCK|RED / yellow          |- |security module *3          |
|     POWER UNLOCK|RED / blue            |- |security module *3          |
|       LOCK MOTOR|WHITE/ red           |   |security module *3          |
|     UNLOCK MOTOR|gray               |   |security module *3          |
|    DISARM DEFEAT|yellow/red          |   |security module *3          |
| PARKING LIGHTS +|RED / black           |   |security module *3          |
|       HEADLIGHTS|blue/black or blue |- |headlight switch            |
|     DOOR TRIGGER|BLACK/ white        |- |security module *3          |
| DOME SUPERVISION|use door trigger    |   |                            |
| TRUNK/HATCH PIN|lt. GREEN/ black     |- |security module *3          |
|        HOOD PIN|lt. green           |- |security module *3          |
|TRNK/HTCH RELEASE|blue/red *4        |5wi|security module *3          |
| FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
| DISARM NO UNLOCK|blue               |- |security module *3          |
|       TACHOMETER|blue               |   |tach test conn. *2          |
|      SPEED SENSE|orange              |   |PCM *5                      |
|       BRAKE WIRE|GREEN / WHITE        |+ |brake switch               |
|     HORN TRIGGER|blue/red            |- |steering column             |
|           WIPERS|blue / YELLOW        |- |steering column             |
| LF WINDOW UP/DN|RED / yel - RED / blue|A |drivers door motor          |
| RF WINDOW UP/DN|blue/yel - blue   |A |drivers door harness        |
|        RADIO 12V|WHITE/ yellow        |+ |radio                      |
|     RADIO GROUND|black               |- |radio                      |
|     RADIO SWITCH|WHITE/ red           |+ |radio                      |
| RADIO ILLUMINATE|RED / black           |+ |radio                      |
|    POWER ANTENNA|yellow/white        |+ |radio                      |
|       LF SPEAKER|blu/grn - gry/blk   |   |radio or amplifier *6       |
|       RF SPEAKER|RED / grn - brn/blk   |   |radio or amplifier *6       |
|       LR SPEAKER|blu/yel - gry/wht   |   |radio or amplifier *6       |
|       RR SPEAKER|RED / yel - brn/wht   |   |radio or amplifier *6       |
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555U. *1 Also found yellow/gray at the security module. Do not use the yellow/gray for remote start. *2 The tach test connector is a 2 pin connector located on the passenger side of the engine compartment by the firewall taped to a harness. *3 The security module is located under the passenger seat.   *4 This wire must be relay isolated from the security module. *5 PCM is under the passenger dash, under the floor board. *6 If equipped, the stereo amplifier is on the right rear corner of the trunk.
Be careful whose advice you buy, but be patient with those who supply it.posted_image
