Aftermarket Climate Control?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=64766
Printed Date: April 01, 2026 at 4:20 AM
Topic: Aftermarket Climate Control?
Posted By: northshoretech
Subject: Aftermarket Climate Control?
Date Posted: October 21, 2005 at 12:23 AM
Anyone know of an aftermarket digital climate control system? I was thinking that I could tie this in with my alarm to set the temperature on remote start so when I entered the car in the summer I could set this up to run the a/c and reset for winter to the heater. Like a regulated thermostat so when its fairly cold the heater kicks in and when its hot the a/c kicks in. Like set to 70 deg. Is this possible? Hmmm???
Posted By: infinkc
Date Posted: October 21, 2005 at 12:49 AM
dei makes a temperature control that starts the car when the temp is too hot or too cold
Date Posted: October 21, 2005 at 1:40 AM
Yeah thats pretty neat, I'm looking for something that will monitor the temp at start time and make the enterior temp match the temp control mark set for the system. So essentially if I had a desired temp. selected when the engine was shut off it would have that as the set mark for cabin temp at start up. Currently I only have the hot cold slide switches instead of the desired degree setting. Solutions?
