Park lights not working, any ideas
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=64882
Printed Date: April 03, 2026 at 11:42 PM
Topic: Park lights not working, any ideas
Posted By: flord
Subject: Park lights not working, any ideas
Date Posted: October 23, 2005 at 12:10 PM
My first install, Ultra Start 4560 in 2001 F250. Checked and rechecked connections? Parking lights to brown wire at headlight switch. Truck starts with remote horn honks,Siren chirps, but no park lights? ------------- Thanks Jim
Posted By: 78musicman
Date Posted: October 23, 2005 at 12:15 PM
some park light outputs have POS and NEG jumpers.Did you see if you have the jumper right
------------- colorado tap the rockies
Posted By: flord
Date Posted: October 23, 2005 at 1:21 PM
Thanks 78musicman, output is POS and is correct. In my manual it says to recheck my blue ignition wire at the 6-pin connector, it is connected to the main ignition wire 0volts in the off and accessory key positions and12V in the ignition and start. I have a selectable output that is not connected, I cant see the need for that. I'll try a second system reset. ------------- Thanks Jim
Posted By: KarTuneMan
Date Posted: October 23, 2005 at 5:03 PM
Pin# 3 on the six pin harness supplies power to the parking light relay. When you have the unit out from under the dash, push lock or unlock.....does the parking light relay "click".....if not look at the connection of red pin3 on the 6 pin main harness.
Posted By: flord
Date Posted: October 23, 2005 at 7:35 PM
Thanks KarTuneMan, Pin #3 has 12V power, I also have an inline fuse that hasent come from togetherness. When I push lock or unlock I dont hear a relay click. Gulp...., does any one know if there is a built in fuse in side an Ultra Start 4560?
