2005 Tahoe rear heat
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=64939
Printed Date: March 22, 2026 at 2:28 AM
Topic: 2005 Tahoe rear heat
Posted By: bassop823
Subject: 2005 Tahoe rear heat
Date Posted: October 24, 2005 at 3:50 PM
My wife has a 2005 Tahoe with rear heat and air. We had a valet 554R installed during the spring. Well it is getting cold here in TN and she used the remote start today and realized the rear heat was not working. The rear heat was just blowing cold air. I told her when she got to work to cut the truck off and restart it with the key then try the heat. She done this and the heat worked fine. My question is should the heat not start working when the key is turned on. Also should the rear heat be working even if she remote starts the vehicle. The shop I had to install the system is know out of businnes, so if this is not to hard to fix I might be able to do it since I have the same valet in a 94 fullsize blazer that I installed myself.
------------- bassop
Posted By: mrcllusb
Date Posted: October 24, 2005 at 4:14 PM
Seems to me that whatever shop hookup ur unit,only tied in the heat to the front system and not both.If you can afford it,find a reputable shop and have them fix ur problem..
------------- "ole blake"
Posted By: mrcllusb
Date Posted: October 24, 2005 at 4:15 PM
I forgot one thing.It seems that all they need to do,is add another relay.
Date Posted: October 24, 2005 at 8:52 PM
I appreciate the help. Do you not think that once turning the key on that the heat should start working even if you remote start the truck or am I looking at this wrong.
Posted By: mrcllusb
Date Posted: October 25, 2005 at 3:08 AM
When you use the key,all the circuits in your vehicle are activated.When you remote start,only the cicuits that are programmed to activate will activate..
Date Posted: October 25, 2005 at 8:53 PM
So even if I remote start the vehicle once the key is inserted and turned on then the heat should work correct. What is happening now is that even once the key is turned on the heat blows, but it is blowing cold airs. The truck has to be cut off and started with the key for the rear heat to work. I have a friend that has just started his own business doing some installs and is going to look into this for me. Thanks for all the help.
