Reason for Diode isolation
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=65008
Printed Date: March 21, 2026 at 7:30 PM
Topic: Reason for Diode isolation
Posted By: flord
Subject: Reason for Diode isolation
Date Posted: October 25, 2005 at 9:21 PM
Please remember I'm a rookie. I've read that you must diode isolate the wait to start wire to prevent the battery from draining on a diesel application. Is the wait to start wire sensing for the wait to start light on the instument cluster to go out. If that is the case no power draw to speak of. Rookie!!
Thanks Jim
Posted By: mo12v
Date Posted: October 25, 2005 at 9:26 PM
Consider the Diode as a 1 way valve.  Lets it out but not back in or visa versa
Try this INFO:
https://www.the12volt.com/diodes/diodes.asp
MO
