2006 Silverado wiring diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=65030
Printed Date: March 22, 2026 at 12:36 PM
Topic: 2006 Silverado wiring diagram
Posted By: hecaya
Subject: 2006 Silverado wiring diagram
Date Posted: October 26, 2005 at 6:42 AM
I am installing a remote starter from DesingTech or its new owner DEI. The manual for the remote starter asks for wires colors that I can't find. I'm having trouble finding the Ignition 2 wire, it is supposed to be a white wire, but their are only two white wires and one is the starter and the other stays on all the thru from the accessory to crank and run.
I'm also having trouble finding the Passlock II wires, on the 05' model they yellow, black, and RED / white. But on the 06' I can't find these three wires together, and their isn't a single yellow wire down there.
If anyone knows if the wires have changed for the 06' silverado and if they know the new diagram I would really appreciate it if you could share it with me.
I'm installing Passlock bypass and I want to know what it means when it asks to connect the wires to the engine side and to the key side.
Posted By: KarTuneMan
Date Posted: October 26, 2005 at 8:58 AM
accs.1 and 2 with ign.2 are in the same harness its over the left hand metal brace, under dash. Leads to the back of the fuse box
orange, white and brown
The passlock black and yellow are sticking out of the junction box right next to that metal brace that I described above
Posted By: mo12v
Date Posted: October 26, 2005 at 9:17 AM
hecaya wrote:
II'm also having trouble finding the Passlock II wires, I'm installing Passlock bypass and I want to know what it means when it asks to connect the wires to the engine side and to the key side.
People are still HARD WIRING PassLocks????posted_image
They should outlaw them............posted_image
When you cut the PassLock wire in half, you will have one side going to Ignition Switch and one side going to "engine side" ( if that is what you want to call it.......)
MO
Posted By: hecaya
Date Posted: October 26, 2005 at 9:48 AM
Thanks to both of you, you have helped me a lot.
When you say the accs.1 and 2 with ign.2 wires are the orange, white and brown does that mean the purplish brown wire is the ign. 2 wire or the is it the white wire because the brown wire is the only one that checks out the right way on my multimeter.
And for the passlock II wires are they the same color as the 05' model (yellow, black, and red w/ white) or are they a different color.
