Viper 550esp, sometimes works?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=65045
Printed Date: March 22, 2026 at 9:28 PM
Topic: Viper 550esp, sometimes works?
Posted By: itsmike
Subject: Viper 550esp, sometimes works?
Date Posted: October 26, 2005 at 12:38 PM
I have the viper 550 esp with remote start installed into my pathfinder. However, it only sometimes arms...
The doors lock/unlocks every time, and the remote start works every time...
Anyone have any ideas what is wrong with my alarm?
Posted By: CutDog504
Date Posted: October 27, 2005 at 12:52 AM
Check to make sure you're not accidentley putting it into valet mode vith the remote. In valet mode, it will still lock and unlock and remote start, but the alarm will not arm. The red LED will be steady on(not blinking) if it is in valet mode. Check that next time it happens.
Posted By: itsmike
Date Posted: October 27, 2005 at 7:57 PM
Okay.. I tried to check to see if its in valet mode.. but my sirens dont work. Any ideas?
Posted By: itsmike
Date Posted: November 05, 2005 at 4:05 PM
Okay... its not in valet mode. Any ideas?
Posted By: Chris Luongo
Date Posted: November 05, 2005 at 5:15 PM
I believe on that unit, if you pre AUX and then quickly press Arm or Disarm, the unit will arm or disarm silently. That's a feature from Viper. Do you think you might be hitting the AUX button by mistake before locking?
Two questions:
1. When the problem happens----when the car locks without making any sound----is the red LED flashing or solid?
2. If the light IS flashing after you've tried to arm it, wait a few seconds, and then verify whether or not the siren works, simply by opening the door with the key.
Posted By: itsmike
Date Posted: November 06, 2005 at 9:52 AM
Two questions:
Hey Chris, thats what I thought at first too, but Im not hitting the aux.   To answer your questions.
1. When this happens. The LED is flashing.   2. And sometime when the alarm is triggered, only the lights flash and the siren doesnt sound.
Do you think its a problem with a short in the siren somewhere?
Thanks for the help!
Date Posted: November 06, 2005 at 11:05 AM
Yes, that does sound like a problem with the siren. Not necessarily a short, but some kind of problem.
The Viper siren is shipped with a long pair of wires---red and black---it is intended that these two wires be run through the firewall and inside the car.
Then, the installer would (inside the car) ground the black wire, and connect the red wire to the brown wire coming from the alarm brain.
BUT, some installers cut the black ground wire short, and ground the siren under the hood instead. It saves time, but the underhood ground can be more likely to corrode or have the screw come loose.
Anyway, now that you have an idea how it works, time to check stuff out.
--Find out how the siren was grounded, and inspect that.
--If you can get behind the dash, inspect the connection of the red siren wire, to the alarm's brown siren output wire.
--Look at how/where the siren wire runs through the firewall, and see if it is getting chafed.
--Look at the siren itself? It is intact and mounted properly? Or have the screws come loose and it's flying around hanging from its wires?
You can get sirens pretty cheap on eBay, and almost any brand would work. (Are you near Boston?). If you're handy with tools, it might be easier to just replace and rewire the whole thing.
