prostart CT3300 door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=65146
Printed Date: April 01, 2026 at 12:50 AM
Topic: prostart CT3300 door locks
Posted By: here2for
Subject: prostart CT3300 door locks
Date Posted: October 27, 2005 at 8:46 PM
Hi all,
I am installing the above unit on a '04 CHEVY TRACKER. The remote has 4 buttons,lock/unlock start and trunk(n/a)
Prostart says in the instructions to connect the grn wire on the 12 pin acc harness to the pnk/grn and the brn on the 12 pin acc harness to the pink. It says the wires on the vehicle are located to the right of the steering column - which they are. I connected as described and nothing happens. posted_image The instructions on prostarts website say that the pink & pink/grn are + but there picture shows them as - ?? In any event if anyone knows how to make it work or can offer advice it would be much appreciated.
Thank You, Chuck
here2for
Posted By: mo12v
Date Posted: October 27, 2005 at 9:01 PM
Isn't  your ProStart EITHER Positive or Negative Lock Output??
If NOT you will need Relays
https://www.directechs.com/directwire/wire_body.asp?action=select&yr=5661&product=Remote%20Start
MO
Posted By: Velocity Motors
Date Posted: October 27, 2005 at 9:07 PM
You will need relays for this connection. (-) trigger from ProStart that requires reversal to (+). Use this digram with 2 SPDT relays:
https://www.velocitymotorsport.com/images/install_notes/N2P.jpg
Posted By: here2for
Date Posted: October 27, 2005 at 9:09 PM
Prostart says they are neg....how do I make them work if that is the case ? :)
here2for
Posted By: mo12v
Date Posted: October 27, 2005 at 9:58 PM
2 SPDT Relays:
Relay 1
LOCK:
PIN 87 = Constant 12 volt ( + )
PIN 87a = XX
PIN 30 = LOCK Wire
PIN 85 = Negative Lock Output from ProStart
PIN 86 = Constant 12 volt ( + )
Relay 2
UNLOCK:
PIN 87 =Constant 12 volt ( + )
PIN 87a = XX
PIN 30 = UNLOCK Wire
PIN 85 = Negative UNLock Output from ProStart
MO
Posted By: here2for
Date Posted: October 29, 2005 at 9:24 PM
Hey Guys, Thanks to all for your help and advice. problem solved
Regards, Chuck
here2for
