F150 Heritage
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=65312
Printed Date: April 05, 2026 at 1:11 PM
Topic: F150 Heritage
Posted By: wyoron
Subject: F150 Heritage
Date Posted: October 30, 2005 at 3:31 PM
Getting ready to install Bulldog 6002 with 791 bypass for remote start. The 04 Heritage usually requires to look up everything for 03 due to body style and design. Should I plan on using 03 or 04 wiring diagrams and color codes? Any special situations I should be prepared for?
Posted By: mo12v
Date Posted: October 30, 2005 at 4:18 PM
2004 Heritage
Constant 12 voltsYELLOW & GREEN/ VIOLETIGNITION SWITCH HARNESS
Ignition 12 voltsD BLUE/L GREENIGNITION SWITCH HARNESS
StarterRED / L BLUEIGNITION SWITCH HARNESS
Dome LightBLACK/ BLUE (+) DRIVERS& PASSENGERS KICK PANEL *
Trunk Pin SwitchN/A
Parking LampBROWN / WHITE (+)HEADLIGHT SWITCH **
Power LockPINK / YELLOWDRIVER KICK PANEL ABOVE ***
Power UnlockPINK/L GREENPARKING BRAKE HANDLE
* Dome Light:(-) Pin Switch Wire Drivers BLACK / YELLOW All Others BLACK/ PINK Located In A 26 Pin Plug At The G.E.M. Above The Fuse Box. ** Parking Lamp Wire Also Located At Six Pin Connector Under Drivers Dash. *** W/ OEM Keyless Entry........Negative Pulse Door Lock .
W/out OEM Keyless Entry ......Reversal Rest At Ground Door Locks.
DoorLock Info: Due To Accessory Power Loss At Generic Electronic Module,Power Door Locks Will Become Inoperable 2 Minutes After Last Door Is Locked And Closed. To wake up the G.E.M Send A Negative Pulse To The YELLOW/BLACK Driver Door Pin Wire With the Unlock Pulse. Diode Isolate Cathode(Band Side) Of Diode Faces Away From Vehicle Wires.You May also Get It At The Drivers Door Boot.
**ANTI-THEFT COLORS:GROUND-BLACK/ LT.BLUE 12VOLTS-RED / LT.GREEN RX SIGNAL-GRAY/ORANGE TX SIGNAL-WHITE/ LT.GREEN
Accessories
Window UpD\ WHT/BLK P\ TAN/BLU D\ YEL/BLU P\ RED / BLK @ MAIN SWITCH
Window DownF/ ORG/WHT F/ WHT/YEL R/ GRY/ORG R/ YEL/BLK
Ign Key WarnBLACK/ PINK (-)PLUG TO RIGHT OF STEERING COLUMN
Trunk ReleaseN/A
OEM HornD BLUE (-)PLUG TO RIGHT OF STEERING COLUMN
HeadlightsRED / YELLOW (+)AT HEADLIGHT SWITCH
OEM Alarm Arm
OEM Alarm DisarmGREEN/ VIOLET (-)AT G.E.M. ABOVE PARKING BRACKET
Reversal Rest At Ground Power Window Circuit
OEM Alarm Horn Wire- YELLOW/LT.GREEN At Fusebox Under Hood. OEM Alarm Hood Trigger- None Listed In Shop Manual.
Remote Start
Tach SignalD BLUE/L GREEN (4.2L)AT COIL PACK ON ENGINE *
Ignition #2GRAY / YELLOWIGNITION SWITCH HARNESS
Ignition #3RED / BLACKIGNITION SWITSH HARNESS
AccessoryBLACK/ LIGHT GREENIGNITION SWITCH HARNESS **
Neutral SafetyNONE GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake LightL GREEN (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightBLACK/ PINK (+)AT SWITCH ON TRANSMISSION
Rear Window DefrostBLUE/ORANGE (-)AT SWITCH
* Wire Color Changes To L GREEN / WHITE On 4.6L and 5.3L Engines. ** Must Be Powered When Remote Started.
Immobilizer Bypass Diagram. OEM Keyless ACC Wire: BLACK/ PINK At GEM Module Located Above The Fuse Box Fuse Box.
MO
Posted By: wyoron
Date Posted: October 30, 2005 at 8:44 PM
Mo,
Great info, Thank You!
