1993 Q 45 door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=65557
Printed Date: March 29, 2026 at 12:51 PM
Topic: 1993 Q 45 door locks
Posted By: rwdog95
Subject: 1993 Q 45 door locks
Date Posted: November 03, 2005 at 5:46 PM
i posted this on oct 26 i am still working on it. is their another type of locking system for this car these wires are not here i hope some one can help me. i am working on a 1993 Q 45 infiniti old i know .i got the wiring diagram from dei and the door lock wires pink/black & ORANGE / blue dont exist in drivers kick panel they said they were a neg- pulse lock system i went to switch in drivers door no pink/black ORANGE / blue there eather cant make them work. probed wires at switch with test light on 12v. will not show ground so did same thing with my vom to no avail this thing is kicking my butt .drivers seat control in same module in door. also there is another big module looks like it dose window and locking system someone help me please!!!!!!
Posted By: 05gt
Date Posted: November 03, 2005 at 5:55 PM
those are the right colors, I checked on 4 different sites
Power Lock ORANGE / blue   -  dr kick or timer mod.
Power Unlock pink/black   -  dr kick or timer mod.
they should be in the driver kick panel, there is a connecter plugged into a module in that area
hope this helps
Posted By: redpeppers
Date Posted: November 03, 2005 at 6:00 PM
check and see if there is a orange (lock) and light blue (unlock double pulse) in the divers door.....it may have wired with a 1994 wiring.....check the door sill....if the MFG date is 06/XX or later than it is usually wired with the next years wiring.
Where theres is a wire there's a way.
Posted By: rwdog95
i tried the conn comming out of the door.i looked at every mod under driver side dash tested every wire that color no luck
Posted By: rwdog95
Date Posted: November 03, 2005 at 6:03 PM
MFG Date is 4/93
Date Posted: November 03, 2005 at 6:06 PM
did u find the timer mod.?
Posted By: kaezoo
Date Posted: November 03, 2005 at 6:08 PM
They might not be the door lock switch wires.  Did you try testing them by turning the key in the lock?  If you can unlock all your doors by turning the key, then those wires may be from the keyhole, not the power lock switches.
Posted By: rwdog95
Date Posted: November 03, 2005 at 6:16 PM
i can unlock all doors with key
Posted By: mo12v
Date Posted: November 03, 2005 at 6:20 PM
They are there........
Power LockPINK/BLACKDOORLOCK TIMER MODULE IN
Power UnlockORANGE / BLUEDRIVER KICK PANEL
Negative Pulse Door Lock Diagram.
Drv Door UnlockRED / WHT OR RED / BLKIN DRIVER KICK PANEL *
OEM RelaysDOOR LOCK TIMER BEHIND DRIVER DASH
MO
Posted By: rwdog95
Date Posted: November 03, 2005 at 6:30 PM
there not there i unbolted every relay every componet looked and tested wire in drivers kick panel but i did not test with key in door by turning
