car wont start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=65626
Printed Date: May 03, 2026 at 7:05 PM
Topic: car wont start
Posted By: shadyband1
Subject: car wont start
Date Posted: November 04, 2005 at 7:01 PM
ok, i tryed installing a thor remote start/alarm system on my 96 cherokee, well, i am no to sure what i did but, when i turn the key, nothing happens and when i hit the start button, the starter trys and keeps cranking but does not turn over, any ideas
Posted By: jrilla
Date Posted: November 04, 2005 at 7:13 PM
Sounds like you may have missed an ignition wire or perhaps switched the ignition wire and the accessory wire. Verify your connections, then if all looks well press start, then quickly put the key in and turn it to the on position (not to start). I say to press start first before turning the key since most starters will not remote start with the ignition on by the key.
------------- J Rilla
Owner/Installer
