Can't find 2002 Civic Parking light wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=6568
Printed Date: April 03, 2026 at 8:03 AM
Topic: Can't find 2002 Civic Parking light wire
Posted By: chillin742
Subject: Can't find 2002 Civic Parking light wire
Date Posted: December 12, 2002 at 3:53 AM
Hello to all -
I'm installing a remote start system in a 2002 Honda Civic EX Coupe.  I've got everything wired up, and it all works beautifully except for one thing - the parking lights don't flash.  I have the parking light output wire from the remote starter connected to a BLACK/ red wire coming out of the headlight switch harness.  I read on a website that this wire could be used.  Obviously, that is incorrect information.  Now, i've researched on this site and found two other answers.  One - back of the fusebox, RED / black wire.  Two - at under dash fuse/relay box, RED / yellow wire.  Now i speant a good half hour under there looking for this wire, but there are just way too many to chose from.  So what I'm getting at is, could someone please point me to a more specific location as to where I can connect this wire?  Not having the parking lights flash makes programming very difficult.  I thank those who respond in advance.
-Pat
Posted By: jrilla
Date Posted: December 12, 2002 at 6:57 AM
If you don't have an option for negative output for parking lights, you can use a relay to change the polarity and grab a blue wire in the factory alarm plug which is located in a green plug above the drivers kick panel.   That is if you cannot find the RED / black on the back of the fuse panel.
J Rilla
Owner/Installer
Posted By: radsta
Date Posted: December 12, 2002 at 2:16 PM
Pat- you can find the wire on the front of the f-box, it's RED / black like most Hondas. There's also a small empty connector in the front of the fbox that goes to this circuit- you'll need a female spade if memory serves me. You can also hit it to the far left in some harness that goes to the auxilary dash switches. .It's a little harder than the old cars, but once you find a spot you like you'll be OK. The circuit is still positive. Let me know of any Honda issues, we do a lot of cars for the local dealer and the rice community!  Steve
victor
Date Posted: December 12, 2002 at 3:20 PM
Thank you all who have responded.  I'm gonna have to give those a try and see what works.  Now, for my next question for you obviously experienced people.  When I went out this morning after remote starting the car, everything was fine (minus the lack of parking light flashes).  But then, when I got in, put the key in, and hit the brake to disengage the remote start, the little green Immobilizer light started flashing on my dash and wouldn't stop.  The car was still running, and the only way to get the light to stop, was to turn the car off and start it up again.  This seems to happen anytime the remote start takes over 'cause I tried the "idle feature" of it which allows you to get out of the car but leave it running without the key, and when I came back, the same thing happened.  I have an OMEGA DB-PKH3 bypass for the engine immobilizer in case you needed to know.  Somebody please help!
-Pat
Posted By: radsta
Date Posted: December 12, 2002 at 3:28 PM
Pat- sounds like a minor wiring issue- check out https://bypasskit.com, they make the pkh3, and have technical support. Steve
victor
Posted By: spart
Date Posted: December 12, 2002 at 4:41 PM
Pat and Victor,
   I too just installed a remote starter system in my car. It was the Cifford solaris in a 2001 civic. Like you said when i remotely start it and get in and do everything right, the green immobilizer light flashes. However sometimes if i leave the key in a little longer maybe 2-3 seconds before i hit the brake, the light comes on...then goes off like it is supposed to. I used the TBHA3 bypass kit made by peripheral. Is it the same thing as a pkh3? Cuz on my the install instructions I received from them there it mentions the PKH3 at the bottom and the wiring instructions are the same.
Dustin
Posted By: jamiejackson
Date Posted: December 12, 2002 at 7:47 PM
theres a 10mm bolt on the front of the fuse block. drop the block down, the parking light is a green (+) wire in the middle of the box, thats your best bet, did one yesterday.
Posted By: 10nesne1
Date Posted: December 12, 2002 at 9:11 PM
The parking light wire is RED / Black (+) is located behind the Fusebox, or you can find it on the harness running infront of the brake pad going to the Fusebox.  Easy to get at.
Good luck
