2 wire door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=65769
Printed Date: May 01, 2026 at 12:26 AM
Topic: 2 wire door locks
Posted By: lewman78
Subject: 2 wire door locks
Date Posted: November 07, 2005 at 1:07 PM
I have a 97 ford escort. I also have a Radiostar Kingeagle(ebay bad idea, I know) alarm. Now my question is While tring to hook up the keyless entry I dont knw what to hook up to what. My car has only one power lock. I think it is stock. I have a Ford remote for it. So in other words, only my driver door has a power lock. I do not have any lock/unlock buttons inside the car. I removed my door pannel. I found the power lock. It has only 2 wares comming from it. If eather is broke The remoe will not work. Some how I need to connect the 6 wires comming from my car alarm to these 2 wires in thte door. I think. Do I need to add relays or is there dome way I can gust connect the wires to make it work? If I do need relays, what kind should I buy? and where are the sold?
Posted By: pitoaudiovisual
Date Posted: November 07, 2005 at 6:49 PM
Go to a web site called Relay Help.com they have all the answers you need for power door .
Confidence is the key to any project!!
Posted By: pss5075104
Date Posted: November 08, 2005 at 9:20 AM
POWER LOCK|gray                |-  |pass. kick panel
POWER UNLOCK|blue                |-  |pass. kick panel
Why do u need to hook up 6 wires???
D
MECP First Class Certified Installer.
Nothing is impossable, it's just more expensive.
Posted By: lewman78
Date Posted: November 08, 2005 at 9:25 AM
There are 6 wires that come from the alarm. They are labled door locks. THe user guide has about 10 different combinations to hook them up to the locks. 2 of the wires are labeled 12v constant. the other 4 are not labeled anything.
Posted By: lewman78
Date Posted: November 08, 2005 at 9:26 AM
does this mean because I have 6 wires comming from the alarm, that I need to buy 2 relays?
And how can I tell If my locks are positively triggered or negatively?
Posted By: jeremyjerm
Date Posted: November 08, 2005 at 1:55 PM
dude it sounds like it has relays built in!
Posted By: KarTuneMan
Date Posted: November 08, 2005 at 6:40 PM
If you have NO SWITCH on the door for lock/unlock, you need to install an actuator in each door....The lock system in this car is controlled by the factory remote ONLY....I know of no way around this problem, other than to add actuators. And yes, the unit has built in relays. (2)
N.O.   N.C.    common
87       87a         30
Posted By: lewman78
Date Posted: November 09, 2005 at 8:46 AM
I figured it out last night. My car has a 4 in one relay system under the dash. I grounded 2 of the wires from the alarm and connected the other 2 to the lock and unlock wires on the built in relay and it worked. I had to rip out half of my dash to get to the damn thing. But this is a learning experence. I have never put in an alarm before, so I may be posting more stupid questions. thanks for the advice.
