555u wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=65940
Printed Date: May 05, 2026 at 9:30 PM
Topic: 555u wiring
Posted By: r1tt
Subject: 555u wiring
Date Posted: November 09, 2005 at 5:42 PM
I've got an old 555u unit that I want to put in in another car. Does anyone have the wiring diagram for the 555u unit
I dont have the original documentation so I don wanna guess on the wiring
thanks
Posted By: cntrylvr79
Date Posted: November 09, 2005 at 6:37 PM
Assuming you're using the antenna ring for it then it goes, red +12volts constant, blue Status input ( ie ground during remote start), and white doesn't get used.  If you're not using the antenna ring then someone else will have to help ya cause I don't remember the other wiring off the top of my head
Cause I'm So white and nerdy...
First Class Certi-fried installer
