Diesel wait to start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=65956
Printed Date: May 05, 2026 at 2:00 PM
Topic: Diesel wait to start
Posted By: Steve23
Subject: Diesel wait to start
Date Posted: November 09, 2005 at 8:19 PM
Hey guys. Im haveing a problem with my Viper 791. Its installed on my 95 f350 diesel. Now thats it been getting cold ive noticed something I didnt notice before. (colder it gets the longer the glow plugs cycle) When I remotely start the truck the starter doesnt wait for the wait to start light to go out. Do I have to program the unit to diesel mode?
Posted By: redpeppers
Date Posted: November 10, 2005 at 12:14 PM
did u hook the wait to start wire up?
Where theres is a wire there's a way.
Posted By: extreme1
Date Posted: November 10, 2005 at 12:48 PM
weird thing I've noticed on the older fords the wts light doesn't come one as soon as the ignition does but a second after, the viper needs the wire to come on with ignition or it won't wait.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Posted By: kgerry
Date Posted: November 10, 2005 at 1:50 PM
the nice thing about the new units coming out of DEI is that they will have a programmable wts delay circuit... you dont even need to go to a glo plug light....
you could always just use a timer module... i've had to do this on many diesels....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: Steve23
Date Posted: November 10, 2005 at 9:21 PM
Yes the WTS wire is hooked up. Like mentioned the wts light doesnt come on right away with the ignition. Where can I get a timer and are they easy to install?
Posted By: mo12v
Date Posted: November 10, 2005 at 9:26 PM
Is that a 791 XV??
MO
Posted By: Steve23
Date Posted: November 10, 2005 at 11:01 PM
Yes, its a 791xv.
Date Posted: November 10, 2005 at 11:32 PM
did u install a diode in-line on the factory wait to start wire between the wait to start blub and the ECM.....negitive side of diode towards ecm.....install wire from alarm between ecm and diode and not between diode and wait to start bulb....try that first and see if that fixs ur prob.  If that doesnt work then u can just turn timer mode on in the programing menu of the brain to wait for 15 to 45 seconds....let me know.....i can tell u how to turn that on if u need me to.
Posted By: Steve23
Date Posted: November 11, 2005 at 3:34 PM
I have the wire hooked up exactly the way you described. Can you tell me how to program the delay?
Posted By: Steve23
Date Posted: November 17, 2005 at 10:48 PM
Does anyone know how to program the 791xv starter to wait before it starts like mentioned above?
Posted By: northern
Date Posted: November 17, 2005 at 11:44 PM
Where do you get a timer module or timer that would simply wait 10-20 seconds before trying to start? I am not using it for DEI products..
Date Posted: November 18, 2005 at 12:51 AM
u can only program the new 791's to do a timer mode.....but DEI has a timer module that will work .......
Posted By: Steve23
Date Posted: November 22, 2005 at 5:08 PM
I got the dei timer module in the mail today. Can someone be kind enough to tell me how to wire it.
Posted By: Steve23
Date Posted: November 25, 2005 at 4:37 PM
bump.
