2wfm8000 vs. 2wfm900
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=65974
Printed Date: May 05, 2026 at 4:08 AM
Topic: 2wfm8000 vs. 2wfm900
Posted By: Justaguy
Subject: 2wfm8000 vs. 2wfm900
Date Posted: November 10, 2005 at 1:43 AM
Anyone have experience with both compustars? My supplier tells me that they've tested both units and the 900mhz unit gets less range, even though there rated at 6000'. I can only get the 434mhz peices from him, which are rated at 5000', so I don't know what to believe. Is it worth getting my hands on a spread spectrum piece so that I can side by side test them? I just want the most range possible.
Posted By: 05gt
Date Posted: November 10, 2005 at 12:39 PM
i have a 2wss-as from compustar, and legitimantly I have gotten about 2000 feet out of it, haven't tried to get anymore, but it worked perfectly fine
I can't see anyone wanting anymore than that for two way communication, cause actually what is the point
if you are over a mile away and your alarm starts to go off what are you going to do, hitch a ride to the vehicle to see what is going on, by the time you get back to the vehicle the theif or whatever was happening to the vehicle will be gone
don't get me wrong remote starting from a distance is the only thing I would want to have good range on
Posted By: autotech mobile
Date Posted: November 10, 2005 at 10:59 PM
I just became a Compustar dealer myself but I think 434mhz version has 800 or 1500' of range. The 1W900FM and 2W900FM's have 3000', and the 2W900FMSS versions have the 6000' range.
Posted By: cluby262000
Date Posted: November 12, 2005 at 5:11 PM
Has any one tried the 2w90fmr or 2wssr.  I live in a apartment bluid and it has a steel roof and probley 1500' or less to my trcuk.  I am wondering which one will work inside my apartment.  I mostly just want remote start, and know that it started, cause I live on the oppiside of the parking lot.  I've been told that the 2wssr would most likely work but was think that the 2w900fmr would be nice for the dallor.
Mike Thompson
Posted By: 05gt
Date Posted: November 12, 2005 at 8:59 PM
well in my previous post I forgot to state taht I do have the 2wss-AS in my car, the AS stands for alarm/starter, I like it alot, I would say you would have no problems with where you are living with that one
