02 dodge ram, keyless entry
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=66005
Printed Date: May 05, 2026 at 4:15 AM
Topic: 02 dodge ram, keyless entry
Posted By: eeh1025
Subject: 02 dodge ram, keyless entry
Date Posted: November 10, 2005 at 2:29 PM
Hey there i have an 02 dodge ram, im hooking up a crimestopper dc2004 II alarm, i at the point of the keyless entry, i have the 820ohm and 330ohm resistor the problem is i dont know what wire to hook them to, also how do you test a negitive trigger what reading should i get out of it? thanks
Posted By: mo12v
Date Posted: November 10, 2005 at 2:47 PM
If you have ON-Board Relays: Hook one side of 820 Resistor to LOCK Wire Hook one side of 220 Resistor to UNLock Wire Then Hook BOTH other ends of Resistors to the WHITE / Dk. Green Wire in Vehicle. TEST DONE
------------- MO
Posted By: eeh1025
Date Posted: November 10, 2005 at 2:49 PM
im going to try that now
thanks
Posted By: fingaz22
Date Posted: November 10, 2005 at 2:59 PM
the lock needs a 867 ohm and the unlock needs a 364 ohm. the wire is wht/grn in the drivers kick panel. to check neg. pulse use a dmm pos probe to a 12vdc feed and the neg. probe to wirer being tested you will see meter increase in voltage. if not you are testing a pos. pulse.
------------- JUST ONE MORE AMP!!!
hu,alpine cva 1005/dva 5205
sound processor,symmetry(first one).
sub amp,power 1000 the terminator.(1992).
subs,spl comp dual 1 ohms.
punch 150hd on a 10" ev.
alotofhighs
Posted By: eeh1025
Date Posted: November 10, 2005 at 3:04 PM
hey there i got the 330ohm unlock to work but the lock dont go down, now i couldnt find a 820ohm resistor so i hooked up 2 of them up in parrel a 330 and a 470 could that be the reason. do i need to hook them up in series
thanks
Posted By: mo12v
Date Posted: November 10, 2005 at 3:14 PM
Needs to be SERIES......One connected to the other
------------- MO
Posted By: eeh1025
Date Posted: November 10, 2005 at 4:02 PM
yo you the man it worked, thanks alot guys
