91 mazda 626 m/t remote install
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=66053
Printed Date: May 05, 2026 at 8:57 PM
Topic: 91 mazda 626 m/t remote install
Posted By: woodvincent
Subject: 91 mazda 626 m/t remote install
Date Posted: November 11, 2005 at 12:27 PM
trying to install prostart ct-3360 in 91 mazda 626 with manual trany both wiring diagrams ive found at 12 volt .com and prostart show different wiring ..can get to tach learn and exit car in ready mode with car running as it is supposed to do and can turn off with transmitter but will not start .all controls will flash park lights except the start button ..it will not signal the remote at all .has any one got a good wiring diagram on this veh  with manual trany
        thanks ...V.Ford
Posted By: redpeppers
Date Posted: November 11, 2005 at 12:30 PM
sounds like u dont have the clutch bypass wire hooked up right......
Where theres is a wire there's a way.
Posted By: davidhdj
Date Posted: November 11, 2005 at 2:11 PM
I just instaled a remote start on a 97 626 with manual trans and linked up the two wires from the clutch, worked like a charm
D&M Auto Parts and Accessories
Date Posted: November 15, 2005 at 7:34 PM
thanks for the ideas linked up both wires at the clutch switch sill will not respond with transmitter ..i still can exit the veh in ready  mode will shut off will start button but still will not start  ..should the park lights flash when i go to start the car..it seems ok with trunk,lock and unlock ...this is a canadian 626 mazda and i would feel alot warmer if i was 100 % sure of proper wiring  at the inigition switch .. as i said have two different wiring diagrams one even shows a secondary ingition.. for the same year..duhhh  and the best is the wiring coulors just dont match  up
where else can i  get a proper wiring diagram
                                                   thanks ..Vince Ford
