1995 Chevy Pickup, Excalibur AL-1000e
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=66101
Printed Date: May 06, 2026 at 10:43 AM
Topic: 1995 Chevy Pickup, Excalibur AL-1000e
Posted By: CRjoslin15
Subject: 1995 Chevy Pickup, Excalibur AL-1000e
Date Posted: November 12, 2005 at 7:30 AM
I am installing an Excalibur AL-1000e on my father-in-law's pickup.  I have almost everything working except for the door input (-).  The wiring diagram says that the wire is purple (-) and in a 4pin black connector in the driver's kick panel.  I didn't see one.  I clipped a purple wire that came out of the pin switch and that didn't seem to make it work either.
I do see a PURPLE / white wire in the driver's kick panel, could this be it?
Also, any ideas on what wire the domelight supervision would be spliced into?
Any help would be greatly appreciated,
CRJoslin
2001 Dodge Ram 1500 V6
Posted By: boomer_106
Date Posted: November 12, 2005 at 7:47 AM
I see a diagram saying purple at the headlight switch so you might want to look for that. I am assuming this is a full size 95 Chevy pickup. The same diagram says to use the same wire for domelight supervision also. Remember to test and make sure that wire does indeed operate the dome light before connecting to it.
CHEVROLET
 MODEL YEAR(S)
 FULL SIZE PICKUP  1995 -
 KEY T-HARNESS IMMOBILIZER
  N/A   GM-1   N/A
 PART  COLOR LOCATION DIAGRAM
 12 VOLT CONSTANT  RED (+)   IGNITION SWITCH HARNESS
 STARTER PURPLE (+) or YELLOW (+)  IGNITION SWITCH HARNESS
 STARTER 2 N/A
 IGNITION 1 PINK (+) IGNITION SWITCH HARNESS
 IGNITION 2 PINK/WHITE (+) or WHITE (+) See NOTE *3 IGNITION SWITCH HARNESS
 IGNITION 3 N/A
 ACCESSORY /HEATER BLOWER 1 ORANGE (+)  IGNITION SWITCH HARNESS
 ACCESSORY /HEATER BLOWER 2 N/A
 KEYSENSE N/A
 PARKING LIGHTS ( - ) N/A
 PARKING LIGHTS ( + ) BROWN (+)  @ HEADLIGHT SWITCH or FUSEBOX
 POWER LOCK LIGHT BLUE (TYPE C)  IN DRIVERS DOOR HARNESS
 POWER UNLOCK WHITE (TYPE C)  IN DRIVERS DOOR HARNESS
 LOCK MOTOR WIRE GRAY (+)  IN DRIVERS KICK PANEL, at DOOR HARNESS
 DOOR TRIGGER PURPLE (-)  @ HEADLIGHT SWITCH
 DOMELIGHT SUPERVISION USE DOOR TRIGGER
 TRUNK RELEASE N/A
 SLIDING POWER DOOR N/A
 HORN BLACK (-)  @ STEERING COLUMN HARNESS
 TACH WHITE  @ ECM, See NOTE *1
 WAIT TO START LIGHT See NOTE *2
 BRAKE WHITE (+)  @ SWITCH ABOVE BRAKE PEDAL
 FACTORY ALARM DISARM  N/A
 ANTI-THEFT N/A
