97 Tahoe, alarm/remote starter
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=66206
Printed Date: May 06, 2026 at 12:16 AM
Topic: 97 Tahoe, alarm/remote starter
Posted By: 350vortec
Subject: 97 Tahoe, alarm/remote starter
Date Posted: November 08, 2005 at 6:57 PM
i have a 1997 tahoe. there are 6 wires in the powerdoor lock switch. How can i tell which wires are normally open and normally closed. Also which wire, for remote start, do i connect the wire from the modual to the started motor?
------------- Thank You Kyle
Posted By: infinkc
Date Posted: November 08, 2005 at 7:43 PM
Power Lock lt. blue either door boot Notes: The 4 door versions are positive trigger, and the 2 door versions are 5-wire. Power Unlock white either door boot Notes: The 4 door versions are positive trigger, and the 2 door versions are 5-wire. Lock Motor gray drivers door boot Unlock Motor tan drivers door boot  ------------- There are 10 types of people in the world, ones that understand binary and ones that dont.
Posted By: slicksam
Date Posted: November 08, 2005 at 10:01 PM
somehow i most likely believe that there 12volt trigger...not positve reversal | Door Lock | Light Blue | Driver's Kick Panel | | Door Unlock | White | Positive Trigger |
find thses and test it like this.......use a jumper connect it to 12volts and TAP!! either wire to see if it locks or unlocks...if it makes a big spark, then use the relays infinkc showed you ------------- Testing is the key
Date Posted: November 13, 2005 at 6:32 PM
I am in the process of hooking up a remote starter. so far the remote will start the engine but the engine will only run for 5 seconds then shut off and restart for another 5 seconds. does anyone have any ideas whats going wrong. Please let me know of anything. Thank you Kyle
Posted By: chris354
Date Posted: November 13, 2005 at 6:56 PM
Need more info but sounds like a tach issue.
Date Posted: November 13, 2005 at 7:48 PM
there is no tach connection for this starter
Posted By: mo12v
Date Posted: November 13, 2005 at 8:00 PM
BASICS first........... YEAR, MAKE & MODEL?? Also MODEL # of R/S would help??
------------- MO
Posted By: mrdakota
Date Posted: November 14, 2005 at 6:34 AM
To me the description teels me it isn't starting it just cranks over. Thus, I would have to guess it is a anti-theft feature at play. Do you have a Vats/Pats system? If so, you'll need an additional module to bypass it. One other thing that occured to me is you might have an ignition-assy swaped. Keith
Date Posted: November 14, 2005 at 1:19 PM
sorry its a 1997 chevy tahoe
and the remote starter is an alguard ag95g
The motor does crankover and does fire, runs for like 5 secs then cut out. what is a Vats/Pats system?
thank you
Date Posted: November 25, 2005 at 10:02 PM
I have a 1997 tahoe and i installed a keyless entry and remote start. If i unlock the doors with the remote then lock them with the button inside the car, the fuse blows out. There must be a short or i hooked something up wrong. Please leave any helpful or ideas that might fix it.
Posted By: 05gt
Date Posted: November 25, 2005 at 10:10 PM
which model tahoe, the two or four door the four door model is positive trigger, and the two door model is 5 wire
Posted By: mo12v
Date Posted: November 25, 2005 at 10:19 PM
Sounds like you have a wire reversed: If you used Relays or did a 5 wire Reversal Rest @ Ground......Make sure you have - PIN 87a - going to Door Switch Side. make sure they are SPDT Relays 2 SPDT RELAYS: Cut LOCK & UNLOCK Wire in Half. One Half goes to SWITCH One Half goes to ACTUATOR Relay 1 LOCK: PIN 87 = 12 Volts ( + ) Constant PIN 87a = wire from Door Lock Switch PIN 30 = wire to Lock side of Actuator PIN 85 = Negative Lock Output from Alarm PIN 86 = Constant 12 volt ( + ) Relay 2 UNLOCK: PIN 87 = 12 Volts ( + ) Constant PIN 87a = wire from Door UnLock Switch PIN 30 = wire to UnLock side of Actuator PIN 85 = Negative UnLock Output from Alarm PIN 86 = Constant 12 volt ( + ) ------------- MO
Date Posted: November 25, 2005 at 11:36 PM
I have the two door. There is no relay, the wires come straight from the alarm module. There a 6 wires. lock and unlock, 2 NO, 2 NC?
Date Posted: December 17, 2005 at 8:03 AM
Hello, i have a 97 tahoe 5.7 and i recently installed a remote starter. Everything worked fine until i found out that when i use the remote start it throws a abs sensor code to the engine light. What connection did i screw up on? Do i need a bypass to solve this, im not sure if the vehicle had an alarm but it did have keyless entry. Any help is appreciated thanks
