2000 F250 Diesel RS install tips
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=66246
Printed Date: May 05, 2026 at 1:10 AM
Topic: 2000 F250 Diesel RS install tips
Posted By: ZQ8pAUL
Subject: 2000 F250 Diesel RS install tips
Date Posted: November 14, 2005 at 12:21 PM
Hey guys I need a wiring diagram, and any tips you may have for installing a compustar 2wss-as alarm/rs into a 2000 ford f250 diesel. Thanks in advance, Paul
Posted By: infinkc
Date Posted: November 14, 2005 at 7:31 PM
FORD / F SERIES SUPER DUTY / 2000 / Remote Start
12volts yellow & lt. GREEN/ purple + ignition harness
Starter RED / lt. blue + ignition harness
Second Starter N/A
Ignition RED / black (larger of 2) + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory BLACK/ lt. green + ignition harness
Second Accessory gray / YELLOW + ignition harness
Keysense BLACK/ pink - ignition harness
Power Lock pink / YELLOW
Notes: Non-keyless versions are 5 wire located in the driver door harness. Keyless versions are negative trigger located in a gray molex plug to the right side of the steering column.
Power Unlock pink/lt. green
Lock Motor pink/black 5wi driver kick, door harness
Unlock Motor pink/black or RED / orange 5wi driver kick, door harness
Parking Lights+ brown + headlight switch
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light BLACK/ pink + relay box under hood
Door Trigger BLACK/ lt. blue + gray plug right of column
Dome Supervision use door trigger
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer WHITE/ pink ac instrument cluster or PCM
Notes: Can also be located in the main harness that runs on the inside of the firewall to the left of the brake pedal.
Wait to start BLACK/ pink - instrument cluster or PCM
Notes: This wire MUST be diode isolated from the instrument cluster to keep the battery from draining, see DirectFax document 1090.
Brake Wire lt. green + brake pedal switch
Parking Brake
Horn Trigger dk. blue - steering column
Just take your time, dont rush, wire it all up before worying why nothing works
------------- There are 10 types of people in the world, ones that understand binary and ones that dont.
Posted By: ZQ8pAUL
Date Posted: November 15, 2005 at 2:45 PM
Thank you very much! Doesn't look like it will be too terribly hard, and as you said, I will be taking my time so that I make sure everything is right and works correctly the first time. Thanks again! Paul
Posted By: Velocity Motors
Date Posted: November 15, 2005 at 8:46 PM
Hey Paul,the Ford trucks are very easy to do. Much the same as a F150 except that wait too start wire.
------------- Jeff
