2000 Pontiac Bonneville
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=66262
Printed Date: May 04, 2026 at 5:22 PM
Topic: 2000 Pontiac Bonneville
Posted By: ksutton
Subject: 2000 Pontiac Bonneville
Date Posted: November 14, 2005 at 6:42 PM
im doing one of these cars and just would like to know is there anything hard or need to know about this car
Posted By: mo12v
Date Posted: November 14, 2005 at 9:08 PM
Pretty straight forward........Depending on your Application: You may need to go to the Battery for Power: | Constant 12 volts | ORANGE | IGNITION SWITCH HARNESS | * ORANGE Wire Is Fused At 15 Amps Only------------- MO
Posted By: northern
Date Posted: November 14, 2005 at 11:06 PM
Mo12v, as a follow up question, what gauge wire would you need to take from the battery to the drivers kick panel?
Posted By: Chris Luongo
Date Posted: November 15, 2005 at 7:54 AM
All the ignition wires in that car are low-current. I use the power source at the ignition switch with no troubles-----use NEGATIVE TRIGGER parking lights, and for the remote starter, install a fuse that is less than 15 amps---a 10, 7.5, or even 5 is fine.
If you don't like the idea of getting power at the keyswitch, there is a thick orange wire in the kick panel under the carpet.
Don't forget that your car has PASSKey III; there's a transponder in the key. You can give up one of your spares and plant it in a bypass box, or it's easy to buy an uncut key from howardkeys.com, hlflake.com, ebay.com, or a local locksmith, and program it yourself.
Posted By: mo12v
Date Posted: November 15, 2005 at 8:10 AM
