weird problem 1997 Toyota Camry
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=66391
Printed Date: May 02, 2026 at 2:52 AM
Topic: weird problem 1997 Toyota Camry
Posted By: 05gt
Subject: weird problem 1997 Toyota Camry
Date Posted: November 16, 2005 at 4:23 PM
Car remote starts fine when the heater controls are off, but when you turn the heater controls on the car won't remote start, it just cranks, I am using a command start 380I, yes I am powering the second ignition properly
I have never seen this problem yet in my couple years of being an installer
someone please help
Thanksyou
Posted By: 05gt
Date Posted: November 16, 2005 at 4:41 PM
figured out the above problem
Now the car starts with the remote, turn the car off and then I try it again and it doesn't start, I reprogram tach and then try it again and it works pefect this happens over and over again
I got the tach off of the fuel injector using a blue wire on one of them
Posted By: KarTuneMan
Date Posted: November 16, 2005 at 4:50 PM
For tach, try BLACK/ orange at the ECM behind the glove box.....4 or 6 cyl. reading depending on the engine size
Posted By: mo12v
Date Posted: November 16, 2005 at 5:41 PM
I would want to verify the Connections also:
Constant 12 voltsWHITE & WHITE/ REDIGNITION SWITCH HARNESS
Ignition 12 voltsBLACK/ REDIGNITION SWITCH HARNESS
StarterREDIGNITION SWITCH HARNESS
Ignition #2BLACK / YELLOWIGNITION SWITCH HARNESS (HEAT/AC/ECM)
MO
Posted By: 05gt
Date Posted: November 16, 2005 at 5:52 PM
hey  mo12V the connections are proper, like I said in my second post I figured out the problem, what is happening is the remote start brain keeps on loosing tach signal, and I have to reprogram everytime
Posted By: mo12v
Date Posted: November 16, 2005 at 6:35 PM
That is why I would verify all connections............The first Post sounds like a wire was not correct......The TACH issue sounds like a MEMORY issue, which sounds like wrong wire..........
Just an observation......Not a cut
who knows ...could be the unit
MO
