Autopage or Ungo Install in 97 Tahoe
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=66397
Printed Date: May 01, 2026 at 11:53 PM
Topic: Autopage or Ungo Install in 97 Tahoe
Posted By: LooneyG
Subject: Autopage or Ungo Install in 97 Tahoe
Date Posted: November 16, 2005 at 6:43 PM
I've got a few questions for you guys, i have a 1997 Chevrolet Tahoe 4WD 4 Door LT Package it has Automatic Locks with a Remote and that's it i was wondering what would be a good 2 Way Alarm/Remote Starter to buy for it, i was looking at either the Autopage RS-855 or the Ungo SR6000 some opinions would be appreciated.
Question number two is what do i need to bypass the factory remote door lock system if anything ???
Thanks Everyone for your help
Posted By: LooneyG
Date Posted: November 16, 2005 at 8:37 PM
Any info on either question would be appreciated
Posted By: Preyhunter
Date Posted: November 17, 2005 at 8:07 AM
I would definitely recommend the Autopage systems. They make a good product. I've used three different Autopage models and they've all been very solid. As I understand it, Ungo makes a solid product, too. I don't think you could go wrong with either brand.
As for a keyless entry bypass, you wouldn't need one. It looks like you don't need an immobilizer bypass, either. You do need to connect the 2nd ignition wire and you may or may not have a 3rd ignition wire. It also looks like your 4 door model is easier to wire for the door locks than the 2 door model.
Looks like a straightforward install. I say go for it.
Posted By: LooneyG
Date Posted: November 17, 2005 at 8:24 AM
Thank you for your response Preyhunter
