94 Cadillac deville problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=66472
Printed Date: April 18, 2026 at 6:22 AM
Topic: 94 Cadillac deville problem
Posted By: prdjr165
Subject: 94 Cadillac deville problem
Date Posted: November 17, 2005 at 6:55 PM
I installed a Crimestopper 2011combo unit today,when I was done I noticed everytime I pushed the brake pedal a cliking sound happened.It only does it with the key on,I looked under the dash and found a torpedo shaped cylinder mounted on the right side of the steering column that is extending everytime I hit the brake pedal,It has a GREEN/ wht wire(hot with ign)and a black wire(always grounded).When I hit the brake pedal the GREEN/ wht wire loses power.Any help would be appreciated!
Posted By: mo12v
Date Posted: November 17, 2005 at 7:21 PM
Are you sure the noise you hear is NOT the Release for the Shifter??
MO
Posted By: prdjr165
Date Posted: November 17, 2005 at 8:00 PM
I'm not sure what this selonoid does,it has a small cable coming out of the front and goes up somewhere in the dash.It might be a release for the shifter,I left it un-plugged because it was heating up,the car will shift with it un-plugged.Do you know the proper operation of this thing?
