2005 Explorer alarm/remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=66556
Printed Date: April 28, 2026 at 2:45 AM
Topic: 2005 Explorer alarm/remote start
Posted By: pitoaudiovisual
Subject: 2005 Explorer alarm/remote start
Date Posted: November 18, 2005 at 9:45 PM
Can anyone please tell me what Direct Fax 1094 is .. Thanx in advance.
------------- Confidence is the key to any project!!
Date Posted: November 18, 2005 at 9:49 PM
I have to do a 2005 Explorer and on the paper it says Can also find at the VSM in the passenger side rear quarter panel below the C pillar. What does VSM stands for and what is the C pillar .. Thanx in advance.... ------------- Confidence is the key to any project!!
Posted By: mo12v
Date Posted: November 18, 2005 at 10:08 PM
# 2..............What are you trying to do? Ford GEM module wake up - normally closed door trigger https://www.directechs.com/techtips/pdfs/resources/security/directed_techtips/1094.pdf ------------- MO
Posted By: mo12v
Date Posted: November 18, 2005 at 10:23 PM
Vehicle Security Module......Or Central Security Module ------------- MO
Posted By: NowYaKnow
Date Posted: November 19, 2005 at 1:03 PM
No reason to go near the VSM. Let me know what your installing and I will give you some tips.
Mike
Date Posted: November 20, 2005 at 1:52 PM
i want to install a remote start/ alarm and it says to go to VSM for power locks and trunk release. any tips would be appreciated
Date Posted: November 20, 2005 at 1:54 PM
yes
Posted By: mo12v
Date Posted: November 20, 2005 at 2:09 PM
| Power Lock | PINK / YELLOW | IN DRIVER'S KICK PANEL | | Power Unlock | PINK/LT GREEN | IN DRIVER'S KICK PANEL | Negative Pulse Door Locks
Trunk/Hatch Release...( + )....ORANGE / lt. grn or PURPLE / yel .....rear hatch harness ------------- MO
Date Posted: November 20, 2005 at 5:38 PM
Locks are:
Pink / YELLOW (-) @ Drivers kick panel/door sill harness
Pink/Green (-) @ Drivers kick panel/door sill harness
Hatch Release:
Pink/Orange (-) @ Drivers REAR door sill or
Purple / YELLOW (+) @ Drivers REAR door sill
Date Posted: November 20, 2005 at 9:23 PM
can you please send me the direct fax #1094. Try to use link and its not connecting.. Thanx
