passlock 1
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=66588
Printed Date: April 27, 2026 at 5:34 AM
Topic: passlock 1
Posted By: auto_sec_paul
Subject: passlock 1
Date Posted: November 19, 2005 at 11:27 AM
Hey everybody, working on a 1996 Pontiac Sunfire w/Passlock 1 and having a bit of bypass trouble. I haven't done passlock 1 in a while and don't have the regular Yellow and ORANGE / Black, wires as with Passlock 2.
In the DEI bypass manual (555L) it says that I need to connect the wires the same as passlock 2 (plus the bulb check wire), but I have a three wire ribbon harness coming from the ignition cylinder that only has two black wires and a BLACK/ white wire. Does anyone know if I need the bypass or not and if so, what wires do I use in this harness?
Vehicle has absolutely no options and no chip in the key but has a theft light in the instrument cluster and a manual transmission.
Thanks.
Posted By: boomer_106
Date Posted: November 19, 2005 at 12:33 PM
Date Posted: December 09, 2005 at 12:37 PM
Thanks,
The next morning at work I figured it out when I looked at the Directechs page I printed off the day before...I was just too blind to see the note at the bottom of the page that said " If your passlock wires are all black........"
I guess next time I'll read the fine print!
Date Posted: December 09, 2005 at 8:02 PM
Good to know you got it
