2005 Malibu remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=66673
Printed Date: April 25, 2026 at 3:58 AM
Topic: 2005 Malibu remote start
Posted By: csorb
Subject: 2005 Malibu remote start
Date Posted: November 20, 2005 at 4:12 PM
First time doing one of these. I tried to measure resistance between the white and the WHITE/ black at the four pin plug at the ignition switch - during start, but I come up with nothing. I am showing continuity at rest but nothing when I turn the key. I tried several meters. Where am I going wrong?
Posted By: mo12v
Date Posted: November 20, 2005 at 6:36 PM
Did you cut the WHITE / Black wire in half and hook one side of Meter to Ignition side of cut WHITE / Black wire & the other side of Meter to WHITE wire?? Hold Ignition Key to the CRANK position even after it stops cranking.....
Money well spent for the OMEGA IB-PLXR ByPASS..........
------------- MO
Posted By: csorb
Date Posted: November 21, 2005 at 8:46 AM
I actually did not cut the wire. I just measured them the way they were. I guess that must explain it?
Posted By: sparkie
Date Posted: November 22, 2005 at 7:27 PM
Get your hands on a module part number PKG 7. It is shown on bypasskit.com. It will look after the start functions as well as the transponder system. It is simple and it works.
------------- sparky
Posted By: redroc
Date Posted: November 25, 2005 at 12:31 AM
I agree with Sparkie get yourself a module,makes life easier.But I thought you only need the pkg7 if there is a cross on the key,if no cross the plxr should do you fine.
