power window wire location for 03’ F-150
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=66689
Printed Date: April 25, 2026 at 10:25 AM
Topic: power window wire location for 03’ F-150
Posted By: jpnuebel
Subject: power window wire location for 03’ F-150
Date Posted: November 20, 2005 at 7:41 PM
Any one know if/where I can get access to the wires for the up/dn of the drivers window in the cab? I just put in a Viper 791 and wanted to control up/dn with the aux outputs. I found the correct wires via the Hanes manual at the switch but I cannot find the wires inside anywhere, that is that I can see going into the GEM.
Am I better off battling running wires to the door?
THANX
jpn
Posted By: Teamrf
Date Posted: November 20, 2005 at 8:03 PM
You should go inside the door to grab window wires.
------------- ~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Posted By: OhioMike1101
Date Posted: November 20, 2005 at 8:08 PM
make sure you use window modules too.
Posted By: Mike M2
Date Posted: November 20, 2005 at 8:15 PM
There's no other choice, it's in the door or nowhere....
Posted By: jpnuebel
Date Posted: November 21, 2005 at 8:59 PM
What does the modules do?
I was just going to use relays sourced from B+ and maybe diode isolate.
jpn
Posted By: Hornshockey
Date Posted: November 23, 2005 at 1:02 AM
The window control module prevents the window motors from burning themselves up trying to continue rolling the window up or down once it has reached the top or bottom of its travel. It is really 4 relays, but is much more convenient and makes for a cleaner install. Most have an input for a ground when armed wire to roll up upon arming; and a ground input for window roll-down on an aux channel. It also provides anti-pinch protection, and one touch operation of the windows from the switches.
------------- Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
