door lock/unlock problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=6680
Printed Date: April 02, 2026 at 6:00 PM
Topic: door lock/unlock problem
Posted By: an8913
Subject: door lock/unlock problem
Date Posted: December 14, 2002 at 2:33 PM
Hi! my 12volt name is an8913, and I have a problem with a 1997 Dodge Intrepid. I installed a remote starter correctly according to the instructions, but the lock and unlock buttons are not working. Does not work from the transmitter and from the lock/unlock button inside of the car. What can I do??
Thank You! an8913@aol.com
JUNIOR
Posted By: Velocity Motors
Date Posted: December 14, 2002 at 4:56 PM
|       POWER LOCK|ORANGE / white *1     |+  |wht plug back of fuse panel |
|     POWER UNLOCK|pink/purple *1      |+  |wht plug back of fuse panel
The wires above are the ones that you needed to tap into. To test the target wire, strip the insulation back and use your DMM  to probe the wire. Toggle the lock/unlock switch and your DMM should register 12 volts when pressed. Make sure that your RS unit can output a + output to the wires because it is a type B system
