97 ford f150, Crimestopper 2011
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=66904
Printed Date: May 14, 2026 at 1:40 PM
Topic: 97 ford f150, Crimestopper 2011
Posted By: mr42022
Subject: 97 ford f150, Crimestopper 2011
Date Posted: November 23, 2005 at 6:07 PM
I recently installed a crimestopper 2011 in a 97 ford f150 after i wired it up i learned the tach . Then went out of programming and remote started the truck . everything was fine . turned the truck off and tried it again and the truck tried to start but stopped cranking early. After that it would not go in sequence ign.1 , ign.2 etc. it would just try to crank imediately and the brain smelled burned (no fuses ever blew anywhere inn the truck or remote starter) . I sent the unit back and they repaired it along with the reason saying that "source of failure, started kill output causing board failure and burnt components" and it said "check your current wiring to prevent this from happening again".
After recieving this i called them and they said that it means that i would need to run a 8 gauge wire to the battery and feed a relay for the cranking of the starter . Has anyone ever heard of doing this ?? I never had to do this in the past with any remote starters. Also can you think of anything else i should check before i install the brain again??
Posted By: mo12v
Date Posted: November 23, 2005 at 9:11 PM
Do you have a Starter Kill Relay wired up?? Have you taken a AMP reading on your Starter Wire? If the Starter section fried, there has to be a reason.....either Module ( which Crimestopper has thier problems ), Starter, or Wiring problem ( Install )..... The Starter does probably draws between 20 - 30 Amps while cranking including the Solenoid.............. If you think it is the Crimestopper......Put a Breaker on the Starter wire & see But I would want to check everything over twice to make sure
------------- MO
Posted By: mr42022
Date Posted: November 24, 2005 at 8:58 AM
I do have a starter kill relay wired up and the truck starts fine with that relay still installed. i haven't taken a amp reading yet but i was going to do that today before i reinstall the unit .
what did you mean by put a breaker on the starter wire?? where should i take the amp reading ?? where i have the starter kill relay hooked up on the starter side a good spot to take the reading??
thanks for the help!!
Posted By: mr42022
Date Posted: November 24, 2005 at 5:23 PM
does anyone know what a breaker is that the previous post suggested
Posted By: mo12v
Date Posted: November 24, 2005 at 5:26 PM
How do you have the Starter Kill wired?? What wires do the PINS go to ?? Are you using a SPDT ( Single Pole Double Throw )Relay? ------------- MO
Posted By: mr42022
Date Posted: November 24, 2005 at 8:39 PM
I am using the relay that comes with the unit . it is still in the truck and it starts fine . It has 2 thick orange wires for the starter and a yellow (to alarmarmed output) and a blue (to ign.1)I think that the guy at crimestopper was saying to hookup another relay to the brown (starter) wire from the remote start so that it would trigger the relay and not draw amps through the remote start unit .i have the remote start wired in as follows .
truck color alarm color
12 volts- GREEN/ purple red (2 wires)
ign. 1- blue/green pink (blue from starter kill relay
ign.2-RED / black pink/white
acc.1-grey / YELLOW gray
starter-RED / blue brown (interrupted w/ orange wires
from relay)
can you see anything wrong with this ?
thanks
shannon
Posted By: mo12v
Date Posted: November 24, 2005 at 9:41 PM
Just trying to help......... How do you have the STARTER KILL RELAY Wires hooked up?? Did you cut Starter wire in Half & wire per instructions?
Starter Kill Relay: YELLOW = Orange wire of 2011 BLUE = Dk.BLUE / Green Ignition Switch ORANGE = Red / L.Blue Ignition Switch Side Starter wire ORANGE = Red / L.Blue Starter Side of Starter Wire
2011: BROWN = Red / L.Blue STARTER Side of Starter Wire
------------- MO
Posted By: mr42022
Date Posted: November 25, 2005 at 8:24 AM
mo,
thanks for the responses, i appreciate any help i can get on this project. Yes that is how I have the relay wired up . I put 2 other crimestopper systems in my other cars with in the last month with no problems. This unit did operate the first time and crapped out after that.
do you think it could have been a bad unit. I always would think it would be something in the install end before the bad unit ,but i am not sure here and i don't wanr to mess it up when i ppower it up again.
Have you done a 97 ford f150 before?? what were the wire color codes that you used for the install.
Thanks for the help!!
Shannon
Posted By: mr42022
Date Posted: November 25, 2005 at 8:27 AM
also another thing that is throwing me off is it never blew any fuses on the 2011 or in the truck , during the install or when the 2011 was malfunctioning .
thanks again
Shannon
Posted By: mo12v
Date Posted: November 25, 2005 at 5:39 PM
If you know the Relay wiring is correct, & the Starter doesn't have unusual drag, I probably would pass it off to a Bad Unit............ As i previosly posted: "If you think it is the Crimestopper......Put a Breaker on the Starter wire & see But I would want to check everything over twice to make sure" Either a Fuse or Breaker in line of the Starter wire from the 2011........ I have done <To Many> F-150's since 1966............ | Constant 12 volts | YELLOW (2), ORG/YEL & | L GREEN/ PURPLE (2) IGN. SW. HARNESS | | Ignition 12 volts | D BLUE/GREEN | IGNITION SWITCH HARNESS | | Starter | RED / L BLUE | IGNITION SWITCH HARNESS | | Dome Light | BLACK/ L BLUE (+) | PASSENGER KICK PANEL | | Trunk Pin Switch | N/A | | | Parking Lamp | BROWN (+) | AT HEADLIGHT SWITCH | | Power Lock | PINK / YELLOW | DRIVER KICK * | | Power Unlock | PINK/L GREEN | PANEL |
* Without OEM Keyless Entry ...........Reversal Rest At Ground Door Locks With OEM Keyless Entry ....Negative Pulse Door Locks | Accessories | | Window Up | D\ WHITE/ BLACK P\ TAN/L BLUE @ MAIN SWITCH | | | Window Down | R/ ORANGE / WHITE S/ WHITE/ YELLOW | | | Ign Key Warn | BLACK/ PINK (-) | IGNITION SWITCH HARNESS | | Trunk Release | N/A | | | OEM Horn | D BLUE (-) | STEERING COLUMN HARNESS | | Headlights | RED / YELLOW (+) | AT HEADLIGHT SWITCH | | OEM Alarm Arm | N/A | | | OEM Alarm Disarm | D GREEN/ PURPLE (-) | DRIVER KICK PANEL |
Reversal Rest At Ground Power Window Circuit | Remote Start | | Tach Signal | WHITE/ PINK | AT POWERTRAIN CONTROL MODULE * | | Ignition #2 | GRAY / YELLOW | IGNITION SWITCH HARNESS ** | | Ignition #3 | RED / BLACK | IGNITION SWITCH HARNESS ** | | Accessory | BLACK/ L GREEN | IGNITION SWITCH HARNESS ** | | Neutral Safety | NOT GROUNDING TYPE - | OEM SWITCH OPENS STARTER CIRCUIT | | Brake Light | L GREEN (+) | AT SWITCH ABOVE BRAKE PEDAL | | Reverse Light | BLACK/ PINK (+) | AT SWITCH ON TRANSMISSION | | Rear Window Defrost | N/A | |
* Powertrain Control Module (PCM) Located On Passenger Side Of Engine Compartment On Passenger Wheelwell. ** See Tech Notes For Additional Information On Ignition Switch Layout.
Ignition Switch Layout. Ignition #1- D BLUE/GREEN............Powers Ignition Coil (Primary Ignition). Ignition #2- GRAY / YELLOW.............Powers Blower Motor Ignition #3- L BLUE/PINK.............Powers Rear ABS Module (W/Rear ABS Only) Ignition #4- RED / BLACK...............Powers Heat/AC Controls * Accessory- BLACK/ L GREEN.............Powers Radio & Windshield Wipers. ------------- MO
Posted By: mr42022
Date Posted: November 25, 2005 at 8:07 PM
what size fuse would you put inline 30amp???
thanks again for all the help
Posted By: mo12v
Date Posted: November 26, 2005 at 7:21 PM
What size Fuses are in your R/ S unit I would want about 5 to 10 amp less
------------- MO
